MikeParker Posted May 15, 2018 Posted May 15, 2018 Thanks for the add to the club. I have a 1970 that I'm replacing the TH350 with a rebuilt 2004R out of a 1987 Grand National. My plan is also to go with 3:73 rear gears and a limited slip carrier My question is are there any recommendations for the horseshoe shifter and cable? This car is also going thru a bench to buckets conversion (I have an open thread in the Interior forum). I have a console I want to install, but with the overdrive, I need some advice on shifter and cable that will work with the console. Quote
Leghome Posted May 15, 2018 Posted May 15, 2018 I have a 700r4 in my 72 Monte and it has the stock floor shift with a shift works conversion kit. I also went with a Bowtie Overdrive TVS cable and linkage kit. Everything works well but I do need to adjust the cable buy have not taken the time to do so Quote
MikeParker Posted May 16, 2018 Author Posted May 16, 2018 Thanks Leghome for the rely -- I see you're not too far from where I was born and raised (Kokomo) . If you have any links to the products mentioned above, please provide. Quote
420ponies Posted May 16, 2018 Posted May 16, 2018 Hi Mike! Welcome to the Madness!! I also have done this upgrade to my '72. Best thing I've done to it!! www.shiftworks.com Quote
Leghome Posted May 17, 2018 Posted May 17, 2018 Here is a link to the Bowtie Overdrive web site. http://bowtieoverdrives.com/ just need to look around and find your carb on one part. I have an Eldebrock 1406 on my 72. this link is also useful http://www.tvmadeez.com/ Link to shiftworks.com http://shiftworks.com/kits.htm If I remember correctly you can contact them and give them your tire size/height and gears you are running and they can hook you up with the correct gears for the speedo cable. Quote
MikeParker Posted May 23, 2018 Author Posted May 23, 2018 I ordered the shifter and conversion kit from ShiftWorks today -- and I also ordered the TV cable from bowtie overdrives -- both should arrive early next week. Thanks for the help, it was much appreciated! Quote
Jared Richey Posted June 10, 2018 Posted June 10, 2018 No need to change the shifter or the cable all you need is a 700R4 bracket conversion kit. Quote
