Anyone where I could find a replacement to splice in until I can afford to rewire the whole car?
Thank you
I looked at that one but my socket has extra wires coming out so I passed it up. Can I still use that one?
Thank you for the info.
I see, but of course that's depicts the left side headlight socket. One wire being the ground, high beam and low beam. The other just daisy chain to the the right beam. I doubt you'll find a socket with dual wires coming out of it, just split or splice the others with the new one. Make sense?
If you're on the market for a new one that's priced right. You can't go wrong with these.
https://www.amazon.com/uxcell-Ceramic-Harness-Sockets-Headlight/dp/B0097AA478?keywords=uxcell+2+x+H4+9003+Ceramic+Wire+Wiring+Harness+Sockets+for+Car+Headlight&qid=1534318990&sr=8-1-fkmrnull&ref=mp_s_a_1_fkmrnull_1
Can you post a picture of your headlight plug? What Rod stated above is true the right side is connected to the left plug. So you would have two light green wires and two tan wires on the drivers side.
