  I'm looking to see if my  Monte is matching numbers, but there is no Vin on the front of the motor. Only Engine assembly stamp with a few number followed by CKN  nothing after that. Does any1 have ideas. Maybe They didn't stamp 1970 402 vins of the front? any idea?
My car is a 1970 Monte  402/400 Flint Michigan built, so there are no build sheets.
Over on Chevelle stuff.net there is an engine chart. CKN- 402, 4bbl, 330hp,LS3, th400. Your engine has the correct code. Most likely the original engine. Could check the casting codes and match them to the cars build date.  Good luck finding the VIN.
