kc8oye Posted September 9, 2007 Posted September 9, 2007 are the 12 bolt diff's 'deeper' then a 10-bolt? I.E the drive shaft yoke sits closer to the engine on a 12 then a 10? I'm trying to figure out how rob's driveshaft is 53" long with a small block & 6" tail housing th350c... but mine is 55" with teh same setup.. the only difference is I have a 10.. he has a 12 bolt. Quote
DavidTX Posted September 10, 2007 Posted September 10, 2007 All I know is that I changed from a 10 to 12 bolt without any change to the driveshaft. That is until I had a 700-R4 installed. Quote
kc8oye Posted September 10, 2007 Author Posted September 10, 2007 hrrm ok, thanks david.. I thought they were the same, but I wasn't sure. I think I'm just going to go ahead and put the trans in, then fit my drive shaft into the trans only, then I can measure ujoint on the driveshaft yoke, to ujoint on the rear diff and see if leo can hook a fella up Quote
