Jared Richey Posted October 3, 2019 Posted October 3, 2019 Went and picked up an SS 454 in Paint Rock AL. Kansas car, very little rust if any. Factory no vinyl car. Black on black. Plan to get it up and running. Possibly restore then sell. Of course it will be available at any time if someone wants a project. 4 Quote
MCfan Posted October 3, 2019 Posted October 3, 2019 Thanks for saving another one, Jared! Looks like you have your work cut out for you for awhile! Quote
714024SPEED Posted October 3, 2019 Posted October 3, 2019 Nice save. Great color combo. Nice to see that another Monte will not be destroyed to make another fake SS Chevelle. 1 Quote
Rob Peters Posted October 3, 2019 Posted October 3, 2019 Looks like a spare grill in the interior. Is the one that is mounted on the car trashed from the front drivers side accident? You didn't say so are we supposed to assume it is all numbers matching? rob Quote
overdrive Posted October 4, 2019 Posted October 4, 2019 Nice! When you say Kansas car, do you mean that's where it spent alot of time? What plant is it from? Dan Quote
Jared Richey Posted October 4, 2019 Author Posted October 4, 2019 It's a Flint built car. Kansas it's whole life I bought it from paint Rock AL, guy bailed on building a 70 SS Fake shovel. He had it shipped from Kansas. The engine is a 73, but all the brackets are correct and nothing missing. All the air ride stuff is here. Pictures from this stage of condition will help document it's authenticity. I'm hoping the transmission is original with the code. Where was it I look for that? Quote
714024SPEED Posted October 4, 2019 Posted October 4, 2019 The VIN should be stamped in the side of the case on a pad just above pan on driver's side near shifter selector. Good luck with it. Quote
Jared Richey Posted October 4, 2019 Author Posted October 4, 2019 Engine is 1973 as told Transmission is 1968 So it's a real SS with without original drivetrain. The 12 bolt rear has the limited-slip tag on it so that was a pleasant surprise.. also the leveling valve is mounted above the rear end as it should be. 2 Quote
Jared Richey Posted October 5, 2019 Author Posted October 5, 2019 I think pictures as these are very important to prove the authenticity of an SS 454 without any paperwork or #s matching drivetrain. Here is the stuff all in a rusty state and obviously on the car since New. Quote
Jared Richey Posted October 7, 2019 Author Posted October 7, 2019 I have the body gutted and ready to come off the frame. I wasn't going to remove the body all the way just simply jack up on each side and replace bushings clean and paint a little but I discovered someone's drag racing in the past caused the rear shock mount to be completely broken away and is gone so that's going to have to be repaired. This car was rode hard and put up wet more than a few times. Quote
Jared Richey Posted October 10, 2019 Author Posted October 10, 2019 Frame is trash.. found more issues Using another one. Already cleaned and epoxied with some Eastwood epoxy.. thick stuff but works great on this pitted frame. Quote
Jared Richey Posted October 10, 2019 Author Posted October 10, 2019 Car is rock solid. Needs the usual rear deck filler. Quote
Jared Richey Posted October 10, 2019 Author Posted October 10, 2019 Coming off the frame tomorrow. Then I can transfer everything over Quote
714024SPEED Posted October 10, 2019 Posted October 10, 2019 Wow you don't waste any time,nice work Quote
1970mcss Posted October 10, 2019 Posted October 10, 2019 Nice to have a spare frame ready and waiting. Great progress. Quote
71MonteCarloMD Posted October 11, 2019 Posted October 11, 2019 Nice progress, What’s a rear deck filler? Quote
dblsprt68 Posted October 11, 2019 Posted October 11, 2019 4 hours ago, 71MonteCarloMD said: Nice progress, What’s a rear deck filler? That is the area between the back glass and trunk lid. Quote
dblsprt68 Posted October 11, 2019 Posted October 11, 2019 VERY KOOL INDEED!!!!! BLACK on BLACK is GORGEOUS!!!!!!!!!!!! Quote
Jared Richey Posted October 11, 2019 Author Posted October 11, 2019 Struck gold on this rear end its a 331 code. 1970 Body is off the frame.already have the interior lined up to be done in a few months. Will be special ordering red door panels. No I try and not waste any time the faster I get it fixed a quicker it can be put on the market 1 Quote
rsorg Posted October 12, 2019 Posted October 12, 2019 hi jared where did you find the rear axle info ,thanks roger Quote
willie Posted October 12, 2019 Posted October 12, 2019 Hey Roger, i think it is on the front side of the axle, drivers side. but someone else can chime in if i am wrong Quote
