70Meangreen Posted June 7, 2020 Posted June 7, 2020 Does anyone have a factory cruise set up in their ‘70 Monte? Any pics of the inner fender area and especially the bracket at the carb would be really helpful. Trying to find the correct throttle/cruise cable bracket at the carburetor. Thanks in advance for the help!! Quote
Jerry Skidmore Posted June 11, 2020 Posted June 11, 2020 I have a friend who has a 70 Chevelle SS 396 convertible with factory cruise control that could get some pictures. Jerry Quote
70Meangreen Posted June 11, 2020 Author Posted June 11, 2020 Thank you Jerry that would really help! Quote
Jerry Skidmore Posted June 11, 2020 Posted June 11, 2020 I sent my friend with the Chevelle an email so as soon as he sends me the pictures I will forward to you. Quote
Jerry Skidmore Posted June 12, 2020 Posted June 12, 2020 The 1970 cruise control lever is chrome and there was also a vacuum canister mounted on the firewall not the inner fender and 71 didn’t have any cruise control but 72 had a black lever with the canister on the inner fender. The linkage was different In 70. Quote
Grant MacPherson Posted June 12, 2020 Posted June 12, 2020 I had a 71 monte with factory cruise. Quote
Jerry Skidmore Posted June 13, 2020 Posted June 13, 2020 It is possible it was dealer installed later. According to Chevelle stuff no cruise control was factory installed in 71 in Chevelle or Monte Carlos. Maybe someone has a build sheet to prove otherwise. Quote
Grant MacPherson Posted June 13, 2020 Posted June 13, 2020 I bought it new in 71, cruise showed on the options list. Never looked for a build sheet, owned it from 71 to 81. It was a GM cruise and looked like the pictures posted? Quote
Paul Bell Posted June 13, 2020 Posted June 13, 2020 730 installed in 1970, 11,510 installed in 1972. Zero in 1971 must be because they lost the records. It was specifically not available on any SS454 Monte Carlos because the superlift pump was mounted where the cruise control was supposed to be. Quote
70Meangreen Posted June 13, 2020 Author Posted June 13, 2020 11 hours ago, Paul Bell said: 730 installed in 1970, 11,510 installed in 1972. Zero in 1971 must be because they lost the records. It was specifically not available on any SS454 Monte Carlos because the superlift pump was mounted where the cruise control was supposed to be. Makes sense about the compressor on the SS models... nowhere to mount the cruise control regulator. Quote
70Meangreen Posted June 13, 2020 Author Posted June 13, 2020 19 hours ago, Jerry Skidmore said: The 1970 cruise control lever is chrome and there was also a vacuum canister mounted on the firewall not the inner fender and 71 didn’t have any cruise control but 72 had a black lever with the canister on the inner fender. The linkage was different In 70. Thanks for the pics Jerry, much appreciated!! ... Pictures really are worth a thousand words!! The vacuum canister that you are referring to is the servo that has the cable attached to the back side according to my 1970 Monte assembly manual. Which brings me to my next question, does anybody know who restores cruise control servos for our Monte’s? Quote
Jerry Skidmore Posted June 13, 2020 Posted June 13, 2020 I made a mistake when I said the server was mount on the firewall it’s on the inner fender like the 72 I was thinking of a 68 impala I saw so the only difference is the chrome lever in 70 and the linkage to the carburetor with the chain in 70 Quote
70Meangreen Posted June 13, 2020 Author Posted June 13, 2020 18 minutes ago, Jerry Skidmore said: I made a mistake when I said the server was mount on the firewall it’s on the inner fender like the 72 I was thinking of a 68 impala I saw so the only difference is the chrome lever in 70 and the linkage to the carburetor with the chain in 70 Got it ... thanks again for all of your help!! Quote
stangeba Posted June 13, 2020 Posted June 13, 2020 I added it about 30 years ago, bought a used assembly from someone in the old Monte Carlo Owners Association. I have trouble with it every 3 years or so. I take it (the thing that both speedometer cables attach to) apart, clean it up and then it works! This picture shows how I attached it to my 350 4BBL (NO A/C) Quote
Paul Bell Posted June 17, 2020 Posted June 17, 2020 Bruce, I think the 1970 cars used a chain at the carb. You 1971 car has no chain but I think it's correct for 71. This is from the 1971 assembly manual. Quote
Wally Haag Posted June 25, 2021 Posted June 25, 2021 Does anyone have a cruise control setup for a 70 Monte Carlo Quote
Paul Bell Posted June 28, 2021 Posted June 28, 2021 It should be the same for 1968-1972 Chevelles so you can widen your search. Quote
