montemason Posted July 12, 2020 Posted July 12, 2020 Hi people, probably a stupid question but is there a trick to getting my inner tie rod off. I got the outer off with no problems but the inner is not coming out. Loosened the castle nut and tried whacking it with a hammer but it's not popping out. Do I need a pickle fork or something? Thanks in advance. Quote
cny first gen 71 Posted July 12, 2020 Posted July 12, 2020 Pickle fork will probably work just fine 1 Quote
montemason Posted July 12, 2020 Author Posted July 12, 2020 Is there a way to do it without the pickle fork or is that the only way? Quote
Leghome Posted July 12, 2020 Posted July 12, 2020 I usually just hit it on the side of the joint with a BFH and they pop right off Quote
cny first gen 71 Posted July 12, 2020 Posted July 12, 2020 Are you replacing the center link also? If so you really dont need to get it out. Quote
montemason Posted July 13, 2020 Author Posted July 13, 2020 I hadn't planned on replacing the center link as it looks to be in good shape still. Quote
jft69z Posted July 13, 2020 Posted July 13, 2020 Try 2 hammers. Set one on the back side as a back up. Then whack the front side with the other hammer. They also have tie rod pullers that press on the stud end, but I've had limited success with them. If the hammer doesn't loosen it in the first place, these won't usually work by themselves. I've used them to preload the stud, then whack it with the hammer & then it usually pops off. These are part of an OTC kit. Also, were you whacking it on the stud end, downward trying to push it out of the hole? If so, try whacking it on the side like Larry above mentioned instead. That'll usually loosen it from the tapered hole. That's what I meant with the 2 hammer thing too, one in back & one in front hitting it from the side of the ball stud. Quote
1Bad454 Posted July 13, 2020 Posted July 13, 2020 The pickle fork works very good. I paid 10 dollars for mine. I just disassembled all of mine. Quote
montemason Posted July 16, 2020 Author Posted July 16, 2020 Thanks guys, bought the $10 pickle fork and it worked great 2 Quote
1Bad454 Posted July 18, 2020 Posted July 18, 2020 Definitely! I've bought a boat load of specialty tools over the last few months for my car restoration. Quote
