kc8oye Posted April 3, 2008 Posted April 3, 2008 Kevin, I had a sender do exactly the same thing. I washed the sender down with NON flamable brake cleaner to get the gas off it.. then I cut that metal 'wire' that goes up to the top of the sender, soldered on a regular wire, cut the 'snap' fitting off, and just ran the wire out thru the hole with a little RTV around it for good measure. that worked great until I got another sender from Leo Quote
Kevin Wiles Posted April 3, 2008 Author Posted April 3, 2008 Jared no autofair for you? I'm not sure what I'm doing yet saturday but I'll let you know. I do need some parts, namely almost all the cables for the emergency brake including the ones that go into the brake drum itself. I'll take inventory and let you know exactly what i need. tim, hopefully my spare sending unit that I almost forgot i had at my dads house works fine. that'll save me 45-55 bucks. btw is it possible to get a new ring that secures the sender into place? they don't include it with a new piece and mine's a little bent. might just hammer it back straight though. Quote
kc8oye Posted April 4, 2008 Posted April 4, 2008 i don't know.. try your local parts store.. you would be amazed at what they can get.. if not, I'm sure leo could help you out Quote
71454SS Posted April 5, 2008 Posted April 5, 2008 One thing I ran into when replacing my sender, the fuel gauge read 3/4 full when I filled up. I had to bend the float rod a little to get a true reading, then I was all set. Quote
Kevin Wiles Posted April 8, 2008 Author Posted April 8, 2008 I'M GLAD TO SAY: It works!! Installed my used fuel sender from "Jared, the Galleria of Monte" and everything is normal. A big thank you to all who helped narrow it down. I learned a lot. kevin Quote
Sam (Bones) Posted April 8, 2008 Posted April 8, 2008 now we just have to get your Alt troubles taken care of Quote
Jared Richey Posted April 8, 2008 Posted April 8, 2008 My head is now huge. Glad I could help you out there Kevin. Quote
