John S Posted January 27, 2021 Posted January 27, 2021 I am going to be replacing my front rotors with drilled and slotted rotors. The question I have for anyone here is as far as the brake pads go would you use the original organic type or would you go to a ceramic or semi metallic? John S Quote
MC1of80 Posted January 27, 2021 Posted January 27, 2021 Power stop! Great stuff. They make a kit with the pads and rotors. My son has them on his 71 Monte and his 69 GTO. I have them on my daily, 2010 Sierra and highly recommend. Quote
cny first gen 71 Posted January 27, 2021 Posted January 27, 2021 I used power stop on the monte seem to work well. I used Detroit axel on my truck they also work well. Kit comes with rotors and carbon fiber ceramic pads and hardware. I did replace the calipers on mine too with stock new ones. A little bit of break in time was required but so far there working very well. 1 Quote
John S Posted January 27, 2021 Author Posted January 27, 2021 57 minutes ago, MC1of80 said: Power stop! Great stuff. They make a kit with the pads and rotors. My son has them on his 71 Monte and his 69 GTO. I have them on my daily, 2010 Sierra and highly recommend. I know This type of rotor there is a difference between right and left side correct? And are they stamped left and right Also did you use the Z 23 rotors or the Z 26 seems as though the Z 26 are the better ones just curious what you used. I looked on power stops’ site and it showed how to tell the difference but I’m still curious which ones you used. Quote
cny first gen 71 Posted January 27, 2021 Posted January 27, 2021 I used the Z23 kit on mine, I didn't really see a difference. Yes there is a right and left they are tagged. Quote
MC1of80 Posted January 27, 2021 Posted January 27, 2021 My son has the z23s on his cars and my truck has the z26s for towing. The rotors have a sticker on them stating which side they go on. Quote
John S Posted January 27, 2021 Author Posted January 27, 2021 Thanks for your help I think the Z 23’s will work just fine and be a nice upgrade. 2 Quote
Paul Bell Posted January 27, 2021 Posted January 27, 2021 If you haven't purchased yet, slotted is OK, drilled only makes the rotors lighter (less mass to absorb braking heat) and don't help in braking. Some crack around the holes. Race cars pretty much stopped using drilled rotors. Quote
714024SPEED Posted January 28, 2021 Posted January 28, 2021 I also used power stop brakes on my 07 Chevy pickup 2500 hd,08 1ton 15 passenger van and will be installing them on my 63 Catalina. Worked great on all of them and the best part No Brake Dust !! 1 Quote
John S Posted January 29, 2021 Author Posted January 29, 2021 I will let you know how they work after I get them installed. John S Quote
John S Posted February 11, 2021 Author Posted February 11, 2021 One more question regarding these power stop brakes installed the rotors and the pads they will not go on the rotor with the caliper pushed all the way back is it acceptable to take those shims off that seems to be the only way they will go on other than sanding pads down which doesn’t sound like a good idea John S Quote
Leghome Posted February 11, 2021 Posted February 11, 2021 On my 72 I never had any problems installing the Power Stop pads and rotors. Now they were a snug fit but after talking to some friends they seemed to think there would be no problem and there has not been. Quote
John S Posted February 11, 2021 Author Posted February 11, 2021 Just now, Leghome said: On my 72 I never had any problems installing the Power Stop pads and rotors. Now they were a snug fit but after talking to some friends they seemed to think there would be no problem and there has not been. I have original calipers I got them from Leo rebuilt them I just don’t believe that the calipers should be hammered on to mount them on the rotors. When I first bought the car the pads on the car were riveted there were no shims on them. The next set of brakes I bought from Napa were riveted pads and they had the shims on them. Right now I don’t see any other option I just wanted to know if anyone else had the same issue I do Quote
MC1of80 Posted February 11, 2021 Posted February 11, 2021 Removal of the shims is what my son had to do to both of his cars. Make sure to coat the back of the pads, where the shim was with "disc brake quiet" or similar product. The shim is an anti- rattle/squeak shim. Quote
John S Posted February 11, 2021 Author Posted February 11, 2021 11 minutes ago, MC1of80 said: Removal of the shims is what my son had to do to both of his cars. Make sure to coat the back of the pads, where the shim was with "disc brake quiet" or similar product. The shim is an anti- rattle/squeak shim. Right I knew that’s why they were in there but previously with other brake pads I’ve never had to remove them. I have some brake silicone type lube that I could put a thin coating on the back of the pads and I think that would work. What do you think? Quote
MC1of80 Posted February 11, 2021 Posted February 11, 2021 As long as it prevents squeaks, you should be good to go. Quote
John S Posted February 11, 2021 Author Posted February 11, 2021 Thanks for the help I’ve got clearance now the rotor spins freely John S 1 Quote
cny first gen 71 Posted February 12, 2021 Posted February 12, 2021 Mine wouldn't go on either but the piston wouldn't go back all the way so I replaced them. The first few stops may feel a little spongy but once they seat in you'll like them. Quote
John S Posted February 12, 2021 Author Posted February 12, 2021 9 minutes ago, cny first gen 71 said: Mine wouldn't go on either but the piston wouldn't go back all the way so I replaced them. The first few stops may feel a little spongy but once they seat in you'll like them. OK I’m hoping so. Quote
Leghome Posted February 12, 2021 Posted February 12, 2021 I followed Power Stops break in procedure to the letter per my son in-law as he has used Power Stop before 1 Quote
TheBMan Posted February 19, 2021 Posted February 19, 2021 I agree with the others who have given a thumbs-up to PowerStop. I've used PowerStop on several cars although not on my Monte Carlo. They work very well and the ceramic pads produce almost no brake dust. Quote
John S Posted February 20, 2021 Author Posted February 20, 2021 As soon as I build up a little ambition I’ll get it back on the road and see how they work. A little cold and wet right now. John S Quote
John S Posted April 12, 2021 Author Posted April 12, 2021 I got my Power Stop brakes and rotors on, bedded them in according to their instructions and the brakes have definitely improved. I always felt that something was wrong with them. I had GM rotors on the car date code F192, June 1972. The surface looked heat hardened, or work hardened and with less than a minimum thickness of .965. I used to work on these cars in the late 70’s to mid 80’s and I know I don’t have the knowledge that many people on this site have, but something always seemed wrong and now with the Power Stop rotors and brakes it is considerably better. On another note I also got rid of the hesitation or bog at full throttle on the Quadra jet. I made some adjustments as per Cliff Ruggles book on Quadra jet‘s and I have gotten rid of the bad hesitation when I nail it. Sometimes there is a very very slight hesitation when I floor it if the RPM is too low but I can live with that, just keep the rpm up and it takes off great. I wish I had that knowledge years ago. It also roasts the tires pretty good on a 3400 RPM clutch dump. John S 4 Quote
wallaby Posted May 20, 2021 Posted May 20, 2021 Let me guess: You tightened the spring tension on the secondary air valves? Quote
