Regmon Posted March 28, 2021 Posted March 28, 2021 Hello. Has anyone used a umi 4034-B reas sway bar and had issues with it not fitting between the lower control arms? I have a set of umi 4024-B non-adjustabe boxed lower control arms and I just purchased a umi rear sway bar 4034-B and I could not get them between the control arms, they seemed to be about a 1/2" to wide. Has anyone else run into the before. Thanks Quote
Blackhawk Posted March 30, 2021 Posted March 30, 2021 Is the car in the air, and if so is it being lifted by the frame or the rear end? Quote
bob 71 Posted March 30, 2021 Posted March 30, 2021 i just put front/rear sway bar umi kit on over the winter rear was tight. had to slide both sides at same time or 1/4 inch at a time. used factory control arms Quote
