Can someone measure the width of the front tires which would be from the outside of the tires. Should be around 70” +
Thanks
the measurement will vary according to wheel/tire width and backspacing
Can you measure yours for me. That would be close enough for me. Thanks
Mine is about 72"+, measured at the bulge of the sidewall near the ground. 225-60R-17
Thanks Joe as always. I’m getting a 4 post lift and its a Advantage 9,000 used. From a friend of mine. My Monte is still in Connecticut. Long story. The ramps are set at 75” os to os. I should be okay. Thanks again my tires are 245/60/15 on 8x15 rally wheels. I think they have a 4” or 4 1/2” backspace
You're welcome Carl.
I forget the back space of the 17" American Racing wheels, but I'm pretty certain you'll be just fine with what you have. It's not like my wheels are any crazy offset or anything like that. Either 4 or 4.5 if I remember correctly.
Good for you on the lift too! 🙂
