Anyone convert from R-12 to R-134? Looking to find out details on how it was accomplished and what parts and supplies are needed. Thank you
Are you recharging with R-12 or R-134?? The original owner of my car said he did the conversion before I bought the car. The air didn't work when I got the car so I had my local shop check out the car and said the poa valve hadn't been changed. We ordered a new poa valve for the R-134 system and now the ac works perfect.
  • RH 70 72 changed the title to 70 Original AC System R -12
R-12
3 hours ago, RH 70 72 said:
R-12
Sorry I didn't read your post close enough. I'm sure someone will give you some ideas. good luck
  • RH 70 72 changed the title to 70 Original AC Conversion R -12 to R 134.
Please let me know what had to be done for your system. I'm going to do the same hopefully soon.
This has been discussed before, found this thread using the search function Hope it helps
