ejw71 Posted July 10, 2021 Posted July 10, 2021 I'm replacing the stock suspension with coil overs. The front coil overs have a plastic cushion for the spring in the lower A arm. Should it also have a plastic cushion in the upper A arm for the top of the spring? Thanks, Ed Quote
7tonemonte Posted July 11, 2021 Posted July 11, 2021 I guess it depends on which manufacturer you use. I just installed Vikings and they had no plastic cushions anywhere. I did get a metal plate off of UMI they had made to reinforce the stock lower arm. It worked awesome. are you using factory A arms? Quote
