Guest JimP Posted June 9, 2008 Posted June 9, 2008 I am looking for a company that makes or has NOS vinyl top material for my 72. I would like to go back originally with a light green vinyl top. The car is Dark Green. Any help appreciated. Thanks, JimP
RichG Posted June 10, 2008 Posted June 10, 2008 You would want a kit from one of the suppliers. The two seams on the roof are "heat sealed" not sewn. An upholstry shop would only be able to sew the seams and negate the issue of NOS material with incorrect appearance. Talk to Leo(Klassik1) he is an excellent supplier and if he sells it to you it will be right!
Rob Peters Posted June 10, 2008 Posted June 10, 2008 From what I understand, none of the ones produced today are quite the same as origional. I think the seam on each side is a couple inches too far toward the center. I think when the reproductions are installed the seam between the trunk and rear window are about an inch or two away from the body seam near the corner of the window and I think the origional ones would run pretty close if not right on that seam.. Rob
