That would work, easiest solution if you're not going to add the aluminum trim pieces.
Get the car, drive it for awhile and be making a list at the same time. There are a ton of options for getting nice parts, original gm or aftermarket, don’t just buy the first thing you see because you need it. There is a ton experience in this group, ask away we will all try to point you in the best direction.
:dt        Good advice.
These might work with a little  rework. Didn’t check if AUVECO still offers them.
