Batman Posted February 18, 2022 Posted February 18, 2022 i have american torque-thrust d 15 x 8- 4.5 rear spacing.i want to put 275/60r15 ta radial on rear of car.anyone have experience or opinion on this fit? Quote
MCfan Posted February 18, 2022 Posted February 18, 2022 Steve, That rim/tire combo should fit - but just barely - unless you trim the inside edge of the wheel well opening flange. Any 8" wide rim with a 4.5" back space has an offset of zero (0) meaning the wheel mounting surface is exactly centered between the inside and outside edges of the rim. I am running the same tire and rim width on the rear of my '70 but my rims have 5.0" back space which is a positive 1/2" (+12mm) offset. That means the wheel mounting surface is 1/2" closer to the outside edge of the rim and therefore the rim/tire combo is moved inboard 1/2" further, increasing the clearance between the outer sidewall and the wheel well flange. I know the clearance between the tire sidewall and the inside edge of my unaltered wheel well flange is right at 3/4" so your rims with only a 4.5" backspace will move your sidewall 1/2" further outboard resulting in only about 1/4" of clearance at the same point (that's why I said "just barely" above). That is not much clearance considering body roll and suspension shift during cornering, hard acceleration or braking. Of course, you can provide up to an inch of extra clearance by trimming the wheel well flange if you are able and so inclined - it's been done many times before. BTW, the tiresize.com website has a Tire Size Calculator and a Wheel Offset Calculator that are invaluable in answering questions such as yours. In fact, if you take the time to carefully measure the clearances of your current tire/rim combo and enter all of that into the two calculators as your current setup, you can then compare any other tire/rim combination to it and see visually and quantitively what it will be on your own Monte. Good luck. Quote
Batman Posted February 18, 2022 Author Posted February 18, 2022 thanks that is alot of good info. Quote
DragCat Posted February 18, 2022 Posted February 18, 2022 5 hours ago, MCfan said: I know the clearance between the tire sidewall and the inside edge of my unaltered wheel well flange is right at 3/4" so your rims with only a 4.5" backspace will move your sidewall 1/2" further outboard resulting in only about 1/4" of clearance at the same point (that's why I said "just barely" above). That is not much clearance considering body roll and suspension shift during cornering, hard acceleration or braking. Yea, I would suggest 5" backspacing. Dennis makes some good points and info Quote
Batman Posted February 19, 2022 Author Posted February 19, 2022 i could only find that wheel with 4.5 bs.i have no problem taking lip back some.its a very nice monte but mot 100% original. Quote
DragCat Posted February 19, 2022 Posted February 19, 2022 I think you'll get some rubbing on conerering for sure, but you already stated the work around. Quote
GatorDog72 Posted February 21, 2022 Posted February 21, 2022 They should fit no problem. That’s the exact set up I have on my car. They are cragar 15x8 4.5 backspace with Mickey Thompson e/t streets in 275/60r15. Didn’t even have to trim the inner lip. The inner side of the tire has about an inch of clearance or more , it’s not even close. Quote
714024SPEED Posted February 21, 2022 Posted February 21, 2022 Inside will be fine. You may have to trim the wheel molding if you have them on your car. Quote
Batman Posted February 22, 2022 Author Posted February 22, 2022 thanks everyone im going to get the tires and go from there. Quote
