anyone know the size of the hole in the lower a frame for the bolt that the swaybar ataches? Mine are egged I did weld them to round again but wonder if they should be sized to the studbolt or if theres abushing? any help appreciated
The holes are known for stripping out. The threads are cut into the frame.
Back in the day we used to slide a nut, inside the frame channel over the hole and install the bolt.
Are you talking about the front lower control arm hole, where the long 3/8" bolt attaches with the bushings & sleeve?
  • 8 months later...
That’s just a 3/8 hole. The sway bar link has a bushing on each side. Bolt, washer, bushing, a arm, bushing, washer, sleeve, washer, bushing, sway bar, bushing, washer and the nut. Now that I think on it, it could be 5/16. Check the size of the long bolt the came in the link kit.
