CloverThe72 Posted June 6, 2022 Posted June 6, 2022 Clover The Monte now runs pretty decently, but one problem has been vexing me: To replace the blinker switch, the previous owner dropped the column. However, he left it there for 25 years... and lost the bolts. Typical bull on this ragged old girl, but nevertheless How do I remount it? What size of bolts, what type of thread would go into such a thing? I want to remount the column, so I can shift my car into drive without the whole column slopping around. Quote
1970mcss Posted June 6, 2022 Posted June 6, 2022 What are you missing?? Any pictures?? I thought the bolts were there and you only need the nuts. I have extra nuts if you need them. I also have an extra non- tilt column. Quote
420ponies Posted June 6, 2022 Posted June 6, 2022 3/8 " 16 thread with washer on nut. That will install it to the steering column bracket.Tractor supply should have it. 2 Quote
Michael Boyte Posted June 6, 2022 Posted June 6, 2022 Should you not have a Tractor Supply , most of the ACE hardware stores have a rather nice selection as well. 1 Quote
CloverThe72 Posted June 7, 2022 Author Posted June 7, 2022 (edited) 18 hours ago, 420ponies said: 3/8 " 16 thread with washer on nut. That will install it to the steering column bracket.Tractor supply should have it. Thanks! It's mounted now, but still slops around side-to-side in the mounting. I've attached a photo of one of the threads in the bottom.of the column. A bolt would probably go through the mounting into the column here to secure the whole thing. Do you know what size bolt this is? Edited June 7, 2022 by CloverThe72 The image didn't attach the first time. Quote
Dtret Posted June 7, 2022 Posted June 7, 2022 That looks like the bracket the has 4 bolts that mounts to the column, then the column lifts up and goes on the two studs on the brake pedal bracket. 1 Quote
Scott S. Posted June 7, 2022 Posted June 7, 2022 I believe it's also 3/8" #16 thread.... 1 1/4" or 1 1/2" long ???? Quote
CloverThe72 Posted June 7, 2022 Author Posted June 7, 2022 11 minutes ago, Scott S. said: I believe it's also 3/8" #16 thread.... 1 1/4" or 1 1/2" long ???? I'll give it a shot! Btw, love your Mad Max Monte. Was thinking of turning Clover into the Nightrider's interceptor. Quote
Scott S. Posted June 8, 2022 Posted June 8, 2022 LOL !!! I can't even remember where I found that photo..... There's a club that re-creates cars and head out to the desert for some rallying. Not sure I'm ready to take Montelishi to that stage just yet though. Quote
CloverThe72 Posted June 9, 2022 Author Posted June 9, 2022 Quick update! The mounting bolts and nuts were 3/8 fine thread. But the four steadying bolts that keep the column from slipping side to side are not. The good news is, while rummaging through Clover's disgusting interior (the car sat in a field for 25 years), I found a bolt which threads into the column perfectly. I still don't know what size it is, but I will take it to Ace and compare threads to find four new replacements. I graduate from community college tomorrow and I'll be celebrating through the weekend so I'll get back to this next week. Thanks for all the help so far! 1 Quote
MC1of80 Posted June 9, 2022 Posted June 9, 2022 That one is too long. These are the ones you need. 3 Quote
CloverThe72 Posted June 9, 2022 Author Posted June 9, 2022 1 hour ago, MC1of80 said: That one is too long. These are the ones you need. But what size are they? 1 Quote
1970mcss Posted June 9, 2022 Posted June 9, 2022 I looked in the shop manual and they don't show the size Quote
MC1of80 Posted June 9, 2022 Posted June 9, 2022 Here is an example from the Chevelle Depot. Just Google 1970 Chevelle steering column bracket mounting bolts. Then take your pick. Quote
