I have 1970 L 48 350 4 BBL in the Monte. The fuel pump is a three line short housing pump. I thought these cars came with the two line pump. The sending unit that was in the car and was replaced with the same style has the two lines on it. I need to replace fuel pump the one that I found is for 1975 Monte with 350 engine I see no reason why that shouldn’t work anybody else have any ideas.
John S
Quote
Yes you can go to the 2 port fuel pump, the 3rd line is a return line, you will need to cap it if you have a vented gas cap.
