Denny Posted November 7, 2022 Posted November 7, 2022 changing balljoints and bushings for my 7o ss 454 wondering if I need to replace a arm shafts , was told from someone once should replace with offset shafts. any input appreciated Quote
Blackhawk Posted December 8, 2022 Posted December 8, 2022 I would only use offset shafts if you can't get a good alignment. https://youtu.be/FpxW7S2EM_Q Quote
cny first gen 71 Posted December 9, 2022 Posted December 9, 2022 20 hours ago, Blackhawk said: I would only use offset shafts if you can't get a good alignment. https://youtu.be/FpxW7S2EM_Q Pretty good video explains it well. I would say if your going 100 percent stock then no, unless you have to to get alignment right. Quote
