Crom Cruach Posted December 16, 2022 Posted December 16, 2022 Finally got the shocks & springs replaced, all new rubber too. the car drives so much better, and the stance is perfect. 10” off the ground behind the front wheel, 12” off at the rear. it was sitting at maybe 8” at the rear before with the old springs, which looked awful. I’m missing some trim (that’s next), and yes, I painted the grille! 11 Quote
Dtret Posted December 16, 2022 Posted December 16, 2022 Looking pretty darn good. Drive it for a little bit now. Enjoy it. 2 Quote
MC1of80 Posted December 16, 2022 Posted December 16, 2022 Great to see the progress you have made! Keep up the great work and like Dennis said, Enjoy it AND drive the wheels off of her! Lol 1 Quote
willie Posted December 16, 2022 Posted December 16, 2022 Looks great Paul, Glad you got all the gremlins out of the way!!! 1 Quote
Glen Posted December 16, 2022 Posted December 16, 2022 Was wondering where you’ve been. Looks great dude. Like Dennis and Tom said, make some time to drive and enjoy her. 2 Quote
Crom Cruach Posted December 16, 2022 Author Posted December 16, 2022 We’re enjoying minus 5 here at the moment (20° in American!) so not much driving this side of Christmas. She’s driving great though. The biggest difference was rebuilding the Quadrajet with larger jets from Cliff Ruggles. My main niggle now is hard starting when hot, which I think is the starter overheating. Going to wrap tne starter with insulation and see if that helps. Quote
Rob Peters Posted December 16, 2022 Posted December 16, 2022 Paul, she is really looking great, I love the background in the shots too. Typical of what someone might see in Ireland. You have come a long way with that Monte, keep the pictures coming!!! rob 1 Quote
Michael Boyte Posted December 16, 2022 Posted December 16, 2022 Your car looks fantastic ! It now has a very nice stance . Now it's time to go and enjoy the fruits of your labor !! 1 Quote
Crom Cruach Posted December 16, 2022 Author Posted December 16, 2022 Cheers lads, no regrets, great motor Quote
1970mcss Posted December 16, 2022 Posted December 16, 2022 Looking good, enjoy the ride. As for the starter, my car came with a heat shield on the starter. It's not factory but i think it helps. The car is put away for a long winters nap but if i think about it I will try to get a picture. Happy Holidays!!! 1 Quote
Scott S. Posted December 16, 2022 Posted December 16, 2022 8 hours ago, Crom Cruach said: We’re enjoying minus 5 here at the moment (20° in American!) so not much driving this side of Christmas. She’s driving great though. The biggest difference was rebuilding the Quadrajet with larger jets from Cliff Ruggles. My main niggle now is hard starting when hot, which I think is the starter overheating. Going to wrap tne starter with insulation and see if that helps. Hard cranking or just takes longer to fire ? Could be vapour lock in the fuel line. If the line sits to close to the manifold, the heat boils the fuel and you get air gaps in the flow. Good to see you're still out there.... And a "Merry Christmas" to ya.... 1 Quote
Crom Cruach Posted December 16, 2022 Author Posted December 16, 2022 On 12/16/2022 at 7:11 PM, Scott S. said: Hard cranking or just takes longer to fire ? Could be vapour lock in the fuel line. If the line sits to close to the manifold, the heat boils the fuel and you get air gaps in the flow. Good to see you're still out there.... And a "Merry Christmas" to ya.... just takes longer to fire Scott. Interesting because it seems to help if I keep my foot on the gas pedal while turning her over. Maybe that’s pushing fresh fuel past the hot stuff? I’ll check that, if I can move the line I will. Many happy returns to all! 🎅 🎄 Quote
420ponies Posted December 16, 2022 Posted December 16, 2022 All I can say is, Awesome! Looks great, and of course it's Blue! Like they say, "Nice day, let's go for a ride!! " 3 Quote
Scott S. Posted December 17, 2022 Posted December 17, 2022 19 hours ago, Crom Cruach said: just takes longer to fire Scott. Interesting because it seems to help if I keep my foot on the gas pedal while turning her over. Maybe that’s pushing fresh fuel past the hour stuff? I’ll check that, if I can move the line I will. Many happy returns to all! 🎅 🎄 Montelishi's like that when she's cold..... But all carbs are like that. I ran an "upsized" steel braided line from the pump to the carb, and after the first run, I can usually start her with just a twist of the key. If I remember right, you've done the filters, tank, lines and pump already, as well as the rebuild.... So that would be my next guess. 1 Quote
stangeba Posted December 17, 2022 Posted December 17, 2022 After sitting for several days or longer, my stock 71 350 Qudrajet 4 BBL, requires that I crank it for around 10+ seconds to refill the float bowl, then it will start and run fine. If I drive it the next day it starts fine. I sealed the "plugs" on the bottom of the carb years ago and they could be leaking again or it just evaporates while sitting. My garage does smell of gasoline after I take it for a ride and it's a warm or hot day. If I had an electric fuel pump, I could turn the ign switch on, let the pump fill the carb and I bet it would start quickly then! I'm sure you already checked that the CHOKE plate closes after the gas pedal is pushed one time to release it when the engine is cold. 2 Quote
cny first gen 71 Posted December 17, 2022 Posted December 17, 2022 Mine does the same thing Bruce I assume it's evaporated and or drained down after a few days. But it always starts. 3 Quote
Montemedic Posted January 6, 2023 Posted January 6, 2023 Check your electrical connections at the starter, (tight and no corrosion) and timing too. Too far retarded or advanced will cause hard starting. 1 Quote
Whons Posted January 18, 2023 Posted January 18, 2023 Love that color blue. I had a 1967 Impala about the same blue. Now I have a 1970 Monte Carlo in dark metallic cherry. My Monte has 2" Drop spindles on the front with an air ride system. 6 Quote
Whons Posted January 18, 2023 Posted January 18, 2023 Thanks, Willie, I just have to finish the lower trim on my Monte. Again I love that blue on your Monte!!!! 2 Quote
willie Posted January 18, 2023 Posted January 18, 2023 Tkx Wayne. Blue and black are my favorite. But there are alot of other colors i really like!! Quote
Dtret Posted January 18, 2023 Posted January 18, 2023 2 hours ago, willie said: Tkx Wayne. Blue and black are my favorite. But there are alot of other colors i really like!! My favorite colors too. 🤪 Quote
Crom Cruach Posted January 18, 2023 Author Posted January 18, 2023 18 hours ago, Whons said: Love that color blue. I had a 1967 Impala about the same blue. Now I have a 1970 Monte Carlo in dark metallic cherry. My Monte has 2" Drop spindles on the front with an air ride system. The curves on that fastback mmmm sexy! I have photos of your Monte saved on my phone because I was playing with the idea of removing the trim but leaving the wheel arch chrome. I think it looks more ‘muscle’ and it looks great, but the original trim look is growing on me more over time. also my lower trim is a bit wrecked, I’m trying to hammer it straighter, but it’s a bit diy! Not that practical to ship it over here because of the length of the pieces. I think if I get her painted I might call Konick and get her done. beautiful cars Wayne Quote
