I didn’t take picture of these fender support brackets prior to disassembly, I know that one end connects to bottom of the front fender but I wasn’t able to identify where the other end connects to, does anyone have a picture to share with me?
If I'm understanding you correctly, the little "bar" brace bolts to the front lower fender by the side marker light assy and the other end bolts to the front 4" filler panel between the radiator support to the inner fender well.
Hey Rick if your asking about the rod in the front of the tire, yes I agree with Tom. But if you are asking about the 1"+- square tube behind the front tire, I think it goes from the frame up to the fender with a bolt through the inner plastic fender about half way down.
Like Willie said the rear square support bolts to the lower firewall, back of the fender and a bolt through the upper part of the fender itself neat the hood hinge forward  mounting bolt.
