Looking at a fitech efi. It comes with the 350 motor it's set up for. If I want it. The block number is 10066038.  92 ish 4 bolt main, made in mexico. Don't know much about motors . Can I use parts from the 350 I have now.  Original  70 010 block late model heads. Has comp cam and roller rockers ( needs bottom end rebuilt ). Yes I know its a no brainer. Efi and motor delivered for cost of the efi.  Thanks
Yes, you can use the older parts on it. The small block didn't change till the lt1s of the 90s I believe. The ones with no distributor and the optispark with the wires by the water pump. Only some parts will interchange with those.
Thanks for the fast reply. Just waiting on the seller to get back to me.
  • You're Welcome 1
