71_402_NC Posted May 15, 2023 Posted May 15, 2023 I am at the point in my project where I am looking at the brakes. I am going with a rear disc conversion kit but don't want to spend the money on a Wilwood system. Especially since I plan on staying with stock 15" rims, and I want the E-brake. So I am looking at single brake caliper setup from The Right Stuff. I am wondering if I should just rebuild my original front brake calipers or go with the Wilwood D52 dual piston calipers for the front. Do they really make a difference? I am on the fence because for the price of the Wilwood calipers I can then get drilled and slotted rotors. Any thoughts you guys have on the calipers and even drilled & slotted vs solid rotors would be appreciated. Thank you Quote
cny first gen 71 Posted May 15, 2023 Posted May 15, 2023 Not sure about the rear conversion but I did do drilled and slotted rotors and carbon fiber ceramic pads on the front, well worth it. I did replace front calipers with new (not rebuilt) factory style calipers and they work just fine. I did the drilled and slotted rotors on all 4 wheels on my truck and like them there too. Quote
MC1of80 Posted May 15, 2023 Posted May 15, 2023 I am right now in the process of rebuilding the front end on Barn Find. My 71 402 auto monte. I purchased new calipers, single piston and will be installing Power Stop drilled and slotted rotors and matching pads. They sell a kit. We have them on our 69 GTO 4speed convertible and our 71 COVID Monte. Just adding these to a stock brake system made a huge night and day difference. 3 Quote
cny first gen 71 Posted May 16, 2023 Posted May 16, 2023 The power stop ones are what I used on my Monte, I used detroit axel on the truck. Both were very good quality. 2 Quote
71_402_NC Posted May 16, 2023 Author Posted May 16, 2023 Thanks for the responses. I decided to go with The Right Stuff rear disc conversion kit with matching front rotors and calipers. Rotors are drilled/slotted and just regular single piston GM style calipers. Now I am waiting for the boxes so I can install. Quote
RON T Posted May 16, 2023 Posted May 16, 2023 Have fun, I thought about doing the rear conversion but decided to stay with new drums, shoes, hardware and pistons- - drilled and slotted rotors and new stock style calipers on the front.. also a new proportion valve.. works great, no problem stopping the big beast , also replaced the brake line hose above the rear gears , it collapses or deteriorates inside. Causing rear brakes to perform poorly... ,!!🛑 3 Quote
Jason72 Posted May 24, 2023 Posted May 24, 2023 I had the wilwood calipers on. I’d say no improvement over stock. Drilled rotors and good pads made a big improvement over stock. I recently upgraded to a 4 piston rear and 6 piston front with larger rotors ( do not remember the diameter at the moment) That along with the hydro boost makes the car stop insanely fast. No problems running hot laps up to 135 mph all afternoon. Quote
