for exhaust. any one done this? i'm redoing my exhaust, could not believe how heavy it was, so this idea came up, save a few pounds and no rust.
feed back please.
thanh
I think for the cost of it verses the gain (weight savings), it not worth the expense, just my 2 cents
not to mention it would most likely melt from the intense heat.
you can imagine if your steel headers are glowing cherry red.. what the aluminum exhaust pipe would be going thru...
actually the aluminum is less expensive then the piping from summit.
tim . i have not seen my exhaust glow after the collectors, but that is something to consider.
they do make header gaskets out of aluminum. so the heat would not be a problem, i don't believe, i could be wrong.
you could be right.
are you sure are not looking at "AluminIZED" pipe?
how much will have to spend to do it in alum, when you already have a exhaust now. I guess I'm getting frugal (cheap) in my old age lol
what do you mean "GETTING" cheap sam? lol
That's one of those ideas that sounds good on paper, but aluminum is troublesome to weld....I would think it wouldn't like to be bent, either.
It's an interesting idea. I wonder if it keeps the noise in?
I have seen oval-shaped pipes, and those would be darn tough to bend, too. There must be an obvious reason why aluminum isn't being used.
