My new aluminum heads don't have the holes where the sensor would normally go on the drivers side. No place on the intake manifold either.
I'm thinking of putting it into a brass tee inline in the 3/4" heater hose close to the intake manifold.
Good place? It may read a few * low.
BBP
You could also get a later model waterneck with the tap built in.
What intake manifold are you using?
that's really odd that your heads don't have that tap either!
sam has a point there.
worked great on my 468, and it puts the temp gauge port right at the thermostat
as long as your t-stat doen't fail 'closed' you'll be fine.
i'm still a big fan of having the sensor right in the head :>
Chris, a water neck like that wouldn't show the correct temperature with the thermostat closed.
My 3/4 heater hose off the intake has flow to the heater even if thermostat is closed. As I said above, there are no sensor holes available.
The engine is assembled & I don't want to drill & tap, IMO too big a risk for introducing chips into coolant passages.
Intake is like an Edelbrock Air Gap, but for for their Pro-Flo EFI
Bones, that's a nice looking one, $92.95 at Summit
BBP
yet again.. Sam has this way of coming up with the ideal solution....
I found it to cure my own problem, my Brodix intake doesn't accept a thermostat, so I needed a way to incorporate one, and the bonus is the two ports just below the stat, perfect location for my stat for the electric fans to boot grin
Mikstudie,
How does your sensor read the correct temperature when the thermostat below it is closed?
I like the diamond plate & will put one on mine. I will mount some stuff there, like the bottom of my DIY shroud & maybe a couple remote oil filters.
I found a more reasonably priced spacer. $39.39
http://store.summitracing.com/partdetail.asp?part=MEZ-WN0028U
BBP
bill, the spacer moves the t-stat up.. because of that, the sensors are UNDER the t-stat, not above it.
I guess I can't see what Mikstudie has there.
"Port in thermostat neck for sensor" sounded like it is above the thermostat.
I know that what Bones is using allows the sensor below the thermostat.
I like it.
BBP
oic.. i'm guessing mikestudie might have only his electric fan sensor there? in which case that's fine, because the fans won't do anything if the t-stat isn't open anyway!!!
I Can't see mike's pic cuz the website squashed it so badly
i ASSumed mike was using what sam showed.
you know what happens when you assume Tim???? lol
mike's is different than mine
yes, I know what happens when I A$$-u-me
I mounted the diamond plate today, lots of uneven surfaces under there, hard to keep the aluminum flat.
I used self tapping screws & 1/4-20 bolts & lots of spacers.
BBP
I hear ya,
I lost my digital camera a couple weeks ago. I was transporting day laborers to my new shop site. Need to buy another one. Darn-it.
BBP
