Denny Posted August 12, 2023 Posted August 12, 2023 have not been on this site for a while..need advice were to get door pannel carpet for my 70 monte. THANKS Quote
Denny Posted August 12, 2023 Author Posted August 12, 2023 how did they fit? satisfied, hard to replace?,Iam in the process of focusing on interior of my rebuild .Looks like I need headliner carpet and seats recovered also. Quote
cny first gen 71 Posted August 12, 2023 Posted August 12, 2023 Parts place will probably have everything you need or legendary 1 Quote
1970mcss Posted August 13, 2023 Posted August 13, 2023 They fit perfectly. They do have to be trimmed. 2 Quote
cny first gen 71 Posted August 13, 2023 Posted August 13, 2023 30 minutes ago, 1970mcss said: They fit perfectly. They do have to be trimmed. Do the carpet trimming after seats are in, not sure if you knew that. Go ahead ask me how I learned that 😅 yup the hard way. 2 Quote
Glen Posted September 6, 2023 Posted September 6, 2023 Got my door panels at Legendary. Fit perfect. As did the headliner from them. Wasn’t cheap, but it looks great 12 Quote
Montemedic Posted September 6, 2023 Posted September 6, 2023 Looking good Glen !! Keep it going ! 1 1 Quote
FrankOC Posted September 7, 2023 Posted September 7, 2023 Interior looks great. Legendary isn't cheap nor fast but they make great products. 6 Quote
Leghome Posted September 7, 2023 Posted September 7, 2023 When I redid ole red’s interior several years ago I used Legendary for my interior Upoholstry and The Parts Place for all of the hardware. Went with the bolstered front seat Upoholstry and am I ever glad I did. Not quite original but I don’t care. So many things had been changed before I got the car it was cheaper to just go with the flow and make it my car not what someone else thought it should be 8 Quote
Jared Richey Posted September 11, 2023 Posted September 11, 2023 Interior is something you have to plan ahead. Nothing is usually in stock. 2 Quote
Joselk1 Posted April 26 Posted April 26 On 8/12/2023 at 10:35 PM, 1970mcss said: They fit perfectly. They do have to be trimmed. Where did you get your door panels? 1 Quote
1970mcss Posted April 27 Posted April 27 The door panels are original. I bought the lower carpet pieces from the Parts Place 2 Quote
Scott S. Posted April 27 Posted April 27 On 8/12/2023 at 8:35 PM, 1970mcss said: They fit perfectly. They do have to be trimmed. Gotta love a green interior. 2 Quote
MI_Custumz Posted April 27 Posted April 27 How do you remove and reinstall the new carpet sections? The more details, the better. Quote
1970mcss Posted April 28 Posted April 28 I took off the door panels off, removed the moldings and the removed the carpet. The carpet had small staples holding it on plus trim adhesive that had lost its adhesion. I then cut the new carpets to fit, sprayed new 3m adhesive and let it dry. I repainted the black part of the moldings and then re-attached them. The molding covers the cut edge of the carpets. I hope that helps. 5 Quote
cny first gen 71 Posted April 28 Posted April 28 Remove seats front and rear, remove cill plates then remove the old carpets. Do whatever prep needed on floors install new carpets the way the old ones came out. It doesn't hurt to lay them out flat for a while first possibly in the sun. Cut holes for seats and reinstall seats. Don't put cill plates on until your sure it's in correctly trim as needed reinstall cill plates. Be careful when you cut holes for seats you got one shot to get it right if you miss it'll show. Ask me how I know 😆 it's now an awful job but a bit time consuming to do properly. 4 Quote
MI_Custumz Posted April 30 Posted April 30 Thanks. I'll reference this post when I decide to get new door panel carpets. The floor carpet tips are helpful too, but carpet is in excellent shape. Quote
