dbreese Posted January 21, 2009 Posted January 21, 2009 I just got my response from Coan, they recommend a 8" w/ a 5000 rpm stall, I'm running a 10" now w/ a 3800 stall, I'm going to call them tomorrow the bad news....it's $795 Pull the trigger Sam!!. Talk with Craig. I spent about the same on mine and don't regret it a bit. David Quote
680HPStroker Posted January 21, 2009 Posted January 21, 2009 Well, you asked. Many have cut corners and learned the hard way. Quote
wallaby Posted January 21, 2009 Author Posted January 21, 2009 Ok, I'm going to bite the bullet, and let the experts tell me what I need. When it comes to converters, I'm uneducated enough that I feel a little helpless in this situation. I'm full of misinformation, so trying to steer the builders into making it the way I think it should be would be a mistake. I just have to sit back and cross my fingers...It's a bit uncomfortable. Now more questions: What target are they aiming for when they select a stall RPM? Do they try to match the stall speed with your torque peak, or what? I can't imagine a big-block that needs a 5000 stall. My HP peaks at about that point, but my torque is long gone by then. (Maybe that's the difference between street and race?) [i'm thinking out loud here] Race converter maybe uses HP peak as a target, and street uses torque peak as a target? Whatever they come up with, I hope it's enough but not too much. Quote
Phil Posted January 21, 2009 Posted January 21, 2009 Mark I would think if you are clear with them and I am sure you will be they will set it to your needs. Quote
AL M Posted January 21, 2009 Posted January 21, 2009 The old "Converter Fright"..A lot of us have been there...take the plunge!!..All I can say is that they make a converter thats tighter than a frogs [censored] under water untill you mash the pedal..It might not feel like stock but you'll get used to it fast and get ready to pay a little extra at the pump. Im curious to see other relpies as well. Good luck! Quote
680HPStroker Posted January 22, 2009 Posted January 22, 2009 Give them your complete engine specifications. Displacement, heads, cam grind, intake, carb, and known/estimated Hp/Tq. Give them your tranny make and any aftermarket parts in it like hardened parts, or shift kit. Give them your rearend specs. Ring/pinion, stock/aftermarket axles, and spline count. give them rear tire size and type. Tell them your primary and secondary use for your car and lastly give them the weight of your car with you in it. That should give them all they need. If they are a good company they will ask most of these questions anyway. Just do it!!!! Quote
wallaby Posted January 22, 2009 Author Posted January 22, 2009 Yep, their form covered all of that and more. I think I'm in good hands. They said it would be an 11" Pro Street series (nickel furnace brazed, billet steel impeller, and three torrington bearings) custom built with 2400-2600 stall. I think it's a bit overkill, but then it should last forever. ***On their questionare form they had a blank space at the bottom labeled "comments". I simply typed: "I don't want the car to drive like a Jet-Ski." Craig thought that was hillarious, and said that was the perfect description. He said he'd probably use that analogy in his future sales pitches. LOL Quote
Sam (Bones) Posted January 22, 2009 Posted January 22, 2009 that is a good description, I understand it completely Quote
dbreese Posted January 22, 2009 Posted January 22, 2009 Yep, their form covered all of that and more. I think I'm in good hands. They said it would be an 11" Pro Street series (nickel furnace brazed, billet steel impeller, and three torrington bearings) custom built with 2400-2600 stall. I think it's a bit overkill, but then it should last forever. ***On their questionare form they had a blank space at the bottom labeled "comments". I simply typed: "I don't want the car to drive like a Jet-Ski." Craig thought that was hillarious, and said that was the perfect description. He said he'd probably use that analogy in his future sales pitches. LOL Wallaby, You won't be sorry with the Pro Street Converter. I ran one for 4 years and never had any issues. I went to their 10" Max performance converter cause of more track time. 3600 stall but because of the stator and fine design it feels darn near stock on the street but wack the loud pedal and it flashes to 3600 and the car just jumps. Craig and the guys hit it dead on for my combo. David Quote
680HPStroker Posted January 22, 2009 Posted January 22, 2009 Whew! I'm glad this one is finally solved. Quote
AL M Posted January 22, 2009 Posted January 22, 2009 Now others will have Converter Envy...lol! Quote
wallaby Posted January 22, 2009 Author Posted January 22, 2009 I was pretty darn happy until I remembered the penalty in gas mileage. In a way I'm glad I never thought of that when I ordered, but now I'm thinking again.... It never ends. LOL Quote
71monteme Posted January 23, 2009 Posted January 23, 2009 I just got my response from Coan, they recommend a 8" w/ a 5000 rpm stall, I'm running a 10" now w/ a 3800 stall, I'm going to call them tomorrow the bad news....it's $795 i don't remember your combo, but i think mine is close to yours and i have a 5000 8" race converter i'm thinking of trying out, i have the 10" tci @ 3200-3600rpm in the car now. after reading this i will be installing the converter for sure. come on spring, time to go racing. i let you know how it goes if your interested. Quote
Sam (Bones) Posted January 23, 2009 Posted January 23, 2009 Originally Posted By: Bones I just got my response from Coan, they recommend a 8" w/ a 5000 rpm stall, I'm running a 10" now w/ a 3800 stall, I'm going to call them tomorrow the bad news....it's $795 i don't remember your combo, but i think mine is close to yours and i have a 5000 8" race converter i'm thinking of trying out, i have the 10" tci @ 3200-3600rpm in the car now. after reading this i will be installing the converter for sure. come on spring, time to go racing. i let you know how it goes if your interested. very interested, or if you want to sell that converter my combo is... 12:1 468 solid roller, canfield 310 heads, single plane w/ 4150 1000HP and a 3.73 gear my first time out was a 11.06, 11.02, 11.002 almost a 10 I know I need a different converter Quote
CrazyDavey Posted July 10, 2009 Posted July 10, 2009 Originally Posted By: 71monteme Originally Posted By: Bones I just got my response from Coan, they recommend a 8" w/ a 5000 rpm stall, I'm running a 10" now w/ a 3800 stall, I'm going to call them tomorrow the bad news....it's $795 i don't remember your combo, but i think mine is close to yours and i have a 5000 8" race converter i'm thinking of trying out, i have the 10" tci @ 3200-3600rpm in the car now. after reading this i will be installing the converter for sure. come on spring, time to go racing. i let you know how it goes if your interested. very interested, or if you want to sell that converter my combo is... 12:1 468 solid roller, canfield 310 heads, single plane w/ 4150 1000HP and a 3.73 gear my first time out was a 11.06, 11.02, 11.002 almost a 10 I know I need a different converter don't know if you ever got that converter Sam but I just ordered a Coan today. I'll let you know how it does...Dave Quote
CrazyDavey Posted July 10, 2009 Posted July 10, 2009 What'd ya order Dave? Scott it's a 10" 3500 Maximum Performance. After long discussions with Craig (great guy by the way) we decided that based on the specs for the Chevelle this would be the one. They're custom making it and he says I will hardly notice it on the street but when you nail it it will flash to 3500 (about the start of my torque curve). He has the specs on the Monte and if I like this I'll get one for Patricia's car when it's done with paint. It's also good for transbrake and NOS if you so desire...Dave Quote
Hisalone Posted August 30, 2009 Posted August 30, 2009 I finally took the plunge and had my converter installed that was custom built a few years back. It was built by Edge Racing Converters and going from a stock converter on my TH400 to this converter with my combination of components really woke the car up and has lost no driveability. In fact, the driveability my have actually improven, but it's hard to tell with the poor condition of my stock suspension. Anyway, I do have a question. Basically the shop serviced my tranny during the install. Before with the stock converter, the tranny shifted really hard under low load, and would even scratch the tires on upshift from first also under low load. The tranny is equipped with a shift kit. However, after the torque converter was installed, it no longer does this. Is this a normal outcome when going to an aftermarket high performance, higher stall converter? The tranny still shifts quickly, it just doesn't give you mild whiplash under low loads. It will still scratch the tires in second on hard acceleration, however. Quote
Sam (Bones) Posted August 30, 2009 Posted August 30, 2009 that's normal, you raised the stall speed so the shifts will seem soft unless you have your foot stuffed in it Quote
Hisalone Posted August 30, 2009 Posted August 30, 2009 that's normal, you raised the stall speed so the shifts will seem soft unless you have your foot stuffed in it Good. Thanks. That's what I figured. And yes, it hits just as hard when I have my foot in it. BTW, this converter was built by a little known company out of Texas I think, and so far, it is everything advertised. I just need a good set of tires because I can't keep it from breaking loose. Quote
CrazyDavey Posted August 30, 2009 Posted August 30, 2009 Hi Joel, you didn't say what stall speed you have but my Chevelle is 3500 and it did soften the 1-2 shift (low speed). The Monte is 2500 and it stayed pretty much the same. A lot can depend on the converter itself, some are looser than others at low speed so that can affect the shift action as well...Dave Quote
kc8oye Posted August 31, 2009 Posted August 31, 2009 yeah, my 2400 stall converter, at light throttle is just as tight as a low stall unit.. drives around town just like a stock converter.. but if I jump on it from a stand still, i can feel the engine 'free rev' up to about 2200 or so then as it continues to rev up, I can feel the converter flash and really begin to pull the car along at quite a clip ~ Quote
Hisalone Posted August 31, 2009 Posted August 31, 2009 Hi Joel, you didn't say what stall speed you have but my Chevelle is 3500 and it did soften the 1-2 shift (low speed). The Monte is 2500 and it stayed pretty much the same. A lot can depend on the converter itself, some are looser than others at low speed so that can affect the shift action as well...Dave Hey Dave. Since my converter was custom built, it doesn't really have an advertised stall speed, however, when watching rpms and mashing the throttle, it jumps to about 3200-3500 (and hold on from there ). It would seem consistent since the cam specs put the beginning of its powerband right in that area. So with that being said, I'd conclude that my Monte and your Chevelle have a converter with similar stall speeds. Dave, how, if at all, has the driveability been affected since you put your converter in. The only thing I notice during regular driving besides the softer upshifts is that it needs ever so slightly more RPM to get it moving, but the difference is almost negligible. Quote
CrazyDavey Posted August 31, 2009 Posted August 31, 2009 mine was custom built too, company named Coan. It drives just about as you describe, pretty happy with it Joel.... Quote
