black07ss Posted November 19, 2023 Posted November 19, 2023 My console trim was broken. How did you install? No directions, looks like it was pinched from the factory. Also looks like a center punch could be used. Quote
MC1of80 Posted November 19, 2023 Posted November 19, 2023 I would try some clear silicone or even better epoxy, used sparingly. Quote
70Monte402 Posted April 9, 2024 Posted April 9, 2024 I would, after removing the old one, place the new one on and check for fit and alignment, tape it in place really tight, flip it over and get a soldering iron with an old tip and then carefully touch the protruding tips to melt them, creating a mushroom of plastic that should not only hold but look close to original. Of course you won't see it once you re-install the internal cover but the satisfaction is high ! 2 Quote
willie Posted April 10, 2024 Posted April 10, 2024 Dennis if you are going to reuse the original, clean it really good first, and also the console cover grove. Sometimes there is stuff stuck in the grove that will not let the chrome strip sit all the way in before you do your repair. 1 Quote
