If you are referring to the center long pieces, yes they are the same. Just flipped over for the upper.
The upper center piece has a slight difference from the bottom one but you could make the bottom one work for the top.
Here’s the upper center trim for a 71 SS. It has a notch cut out of it.
16 hours ago, Rich 71 said:
ok thanks where can i get the upper one with the notch
The upper one with the notch is not reproduced as far as I know. You would need to find a good used upper one or buy the reproduction lower one which should still fit.
The Parts Place labels that part as 1970-71 lower and 1971 upper (ie, same part upper and lower).
https://www.thepartsplaceinc.com/product/1971/1971-chevrolet-monte-carlo-rear-body-panel-molding-1970-71-lower-and-1971-upper-mounts-to-the-rear-body-panel-gm-8700888-ea/36391
Also note that the reproduction upper end pieces (often referred to as hockey sticks) do not fit as well as the originals but they still work fine. If you are concerned about it being as factory correct as possible then finding originals would be ideal but not always easy to find and not cheap.
You'll need to buy the lower piece and you can easily modify it to fit correctly. Just file it to the shape that Aaron showed to fit around the raised area by the latch.
Dan
