black07ss Posted March 16, 2024 Posted March 16, 2024 Looking for a picture of the 71-72 vinyl top trim at the front window. 1 Quote
Rob Peters Posted March 16, 2024 Posted March 16, 2024 32 minutes ago, Dtret said: There is none. I could be wrong but Bob may be looking for pictures of how the vinyl top trim on the 70 with full halo is routed and/or how the vinyl material on some 70 and all 71/72's tuck into the windshield trim. rob 1 Quote
black07ss Posted March 16, 2024 Author Posted March 16, 2024 19 minutes ago, Rob Peters said: I could be wrong but Bob may be looking for pictures of how the vinyl top trim on the 70 with full halo is routed and/or how the vinyl material on some 70 and all 71/72's tuck into the windshield trim. rob You are correct Rob. I'm looking at how far the vinyl top trim goes to the top of the windshield Quote
Dtret Posted March 16, 2024 Posted March 16, 2024 Joe said he’s going to snap a picture of his car when he goes out to the shop. If not I can pull the cover off my 71 and snap as many as you need 1 Quote
jft69z Posted March 16, 2024 Posted March 16, 2024 1 minute ago, Dtret said: Joe said he’s going to snap a picture of his car when he goes out to the shop. If not I can pull the cover off my 71 and snap as many as you need I'll be of no help then, because my 72 vinyl goes the full way & tucks under the W/S trim. 1 Quote
black07ss Posted March 16, 2024 Author Posted March 16, 2024 3 minutes ago, jft69z said: I'll be of no help then, because my 72 vinyl goes the full way & tucks under the W/S trim. Yes exactly goes into the window channel. I would like the trim to dead end into the window trim further but then it only leaves a +1/4" where it slides into the Z shaped trim. Quote
Dtret Posted March 16, 2024 Posted March 16, 2024 I pulled this from the internet because it shows both. 1 Quote
jft69z Posted March 16, 2024 Posted March 16, 2024 I thought you were talking about the halo trim, and how it sits across the front. Here's mine. Can't go much more forward than that, or it'll be sticking out/up too much. There's a natural bend/curve in the trim that matches the curve of the roof line too. It appears to sit just right on what I have. 4 Quote
black07ss Posted March 16, 2024 Author Posted March 16, 2024 4 hours ago, Rob Peters said: I could be wrong but Bob may be looking for pictures of how the vinyl top trim on the 70 with full halo is routed and/or how the vinyl material on some 70 and all 71/72's tuck into the windshield trim. rob You are correct Rob. I'm looking at how far the vinyl top trim goes to the top of the windshield 2 Quote
black07ss Posted March 16, 2024 Author Posted March 16, 2024 Thanks Joe that is the picture I am looking for. I would have thought it was a little closer to the windshield trim 1 Quote
jft69z Posted March 16, 2024 Posted March 16, 2024 11 minutes ago, black07ss said: Thanks Joe that is the picture I am looking for. I would have thought it was a little closer to the windshield trim It will slide fore & aft a bit, but in my case that seems to be a good spot. As mentioned above, too far forward would maybe stick out/up too much. I'm not sure how deep it goes in the rear 'Z' piece, but both sides of the car are setup the same distance from the W/S trim. 3 Quote
overdrive Posted March 17, 2024 Posted March 17, 2024 Joe, your "non halo" photo is an aftermarket top. Truly non halo. Dan Quote
jft69z Posted March 17, 2024 Posted March 17, 2024 3 minutes ago, overdrive said: Joe, your "non halo" photo is an aftermarket top. Truly non halo. Dan Did you mean Dennis' photo? Quote
Dtret Posted March 17, 2024 Posted March 17, 2024 1 hour ago, jft69z said: Did you mean Dennis' photo? I hope so. Yours is correct. The non-halo I posted was a dealer install vinyl top. At the time the question was posted I thought that was what he was looking for. As the post moved further along it got more specific. 2 Quote
Canuck Posted March 17, 2024 Posted March 17, 2024 1 hour ago, jft69z said: Did you mean Dennis' photo? I think he meant Dennis' photo. 2 Quote
black07ss Posted March 18, 2024 Author Posted March 18, 2024 On 3/16/2024 at 10:22 AM, Dtret said: Joe said he’s going to snap a picture of his car when he goes out to the shop. If not I can pull the cover off my 71 and snap as many as you need Thanks Dennis Quote
overdrive Posted March 19, 2024 Posted March 19, 2024 On 3/17/2024 at 10:04 AM, jft69z said: Did you mean Dennis' photo? Yes, sorry. It's his photo. Dan 1 Quote
