Chevyss Posted March 15, 2009 Posted March 15, 2009 Just curious what kind of mileage a person might get with a 502? I haven't got a chance to drive it on the open road yet, still in the break in stage. 502 w/700r4 and 3.73. Hoping to drive it to car shows this year and wonder what to expect. Quote
Shadow Gray SS Posted March 15, 2009 Posted March 15, 2009 My 454 (460) is getting 7-8 mpg just cruising around. Still breaking in though. Quote
502ci Posted March 15, 2009 Posted March 15, 2009 My ZZ502 gets 13 mpg on average with my overdrive. My car has 4.11 gears but the ovedrive knocks it down to 3.22. I always end up putting my foot into it every time so I know it can get better. Your overdrive should knock your ratio down to like a 2.60 something so I would think you would get better...although I don't know how your 502 is built. Bill Quote
Mike 57 Posted March 15, 2009 Posted March 15, 2009 I am getting 13 wih my 5o5 on the highway 3.42 gear with a turbo 400. If I drop the hammer milage goes out the window. Quote
Chevyss Posted March 15, 2009 Author Posted March 15, 2009 Straight GMPP ZZ502. Nothing has been done to it. 850 vacumn secondaries. If I ever quit doing things to it and get a chance to hit the road I'll be able to find out. If it's to bad it will become a trailer queen. Quote
Heckeng Posted March 15, 2009 Posted March 15, 2009 You won't enjoy it as much if you have to trailor it everywhere! Just my opinion of course. The key to mileage is to keep the rpms low, even when cruising to shows. Drive slow and I bet you can get 15 or higher, especially with that OD. Quote
Guest XXXXXXX Posted March 15, 2009 Posted March 15, 2009 The way I've always looked at it is, if you're gonna own a big block hot rod you can't be too worried about milage. Never bothered to check mine. 402,th400, 3:48 gears. I don't think I go thru an excessive amount of gas. Quote
Cali Z28 Posted March 15, 2009 Posted March 15, 2009 My 548 gets a robust 5-6 miles to the gallon!!!! A little better on the highway in overdrive. Horsepower and fuel mileage do not go together well. Quote
Shadow Gray SS Posted March 15, 2009 Posted March 15, 2009 I have been monitoring mine to prepare myself for the Polson trip. I am gonna have to sell some blood or plasma for gas money Quote
Chevyss Posted March 16, 2009 Author Posted March 16, 2009 The Polson trip is going to be a driver if the Monte gets decent fuel mileage. 15 would be good. Yes, I built it to drive. Quote
502ci Posted March 16, 2009 Posted March 16, 2009 What carb are you running Bill? A Holley 850 with vacuum secondary's...this came stock on the ZZ502 crate motor. Bill Quote
Shadow Gray SS Posted March 16, 2009 Posted March 16, 2009 So with my Holley 770, it is not unreasonable to expect at least low teens once everything settles in and cruisin' on the highway in OD, right? None of the driving I have been able to do has been highway and the numbers have me wondering what it will cost to drive to Polson. Quote
kc8oye Posted March 16, 2009 Posted March 16, 2009 I miss my Qjet for the one reason of fuel milage.. it did WAY better the my holley carb.. but I manage about 11-12mpg in 3rd gear @ 70mph (3300 rpm) and when my overdrive actully works.. I can run about 18-19mpg @ 70 (2250 rpm) but that's with my little 355 ~ Quote
