70Monte402 Posted April 10, 2024 Posted April 10, 2024 Factory "horseshoe" shifter, seems that it's out of adjustment a little. As you bring the shifter to the D position, it hits the detent but it's not really in gear. You have to pull up on the release handle and pull it just a 1/4 inch past the detent towards 2nd to get it to go into D. You can then push it back up to "click" it back into the detent. Anyone know where this needs to be adjusted? and how? Thanks Dennis Bagwell Quote
FrankOC Posted April 10, 2024 Posted April 10, 2024 You can adjust on the shifter at the point where the cable connects, (there is a slotted bracket for adjustment),and you have some adjustment at the transmission as well. 4 Quote
DragCat Posted April 10, 2024 Posted April 10, 2024 Good info in this old thread https://www.firstgenmc.com/forums/index.php?/topic/10744-linkage-pic-required/#comment-225666 2 Quote
MC1of80 Posted April 11, 2024 Posted April 11, 2024 I believe we recently helped someone with the same type issue. Quote
