David Schellhorn Posted June 6, 2024 Posted June 6, 2024 Gear shift indicator doesn't come off park. Cable? Quote
cny first gen 71 Posted June 6, 2024 Posted June 6, 2024 Yup sounds like cable is broken or disconnected 1 Quote
Dtret Posted June 6, 2024 Posted June 6, 2024 The screw may have come out. But most likely broken. 2 Quote
Scott S. Posted June 6, 2024 Posted June 6, 2024 Welcome to the insanity David... Assuming you're dealing with the dash indicator, the wire is probably snapped.... Unless someone has worked on/taken apart the steering and forgot to put the screw back. 1 Quote
stangeba Posted June 6, 2024 Posted June 6, 2024 I know very well where this fragile thin wire attaches to the steering column on my 71 Monte, and I still broke it one time!! 2 Quote
