Dtret Posted July 22, 2024 Author Posted July 22, 2024 16 minutes ago, Ron Tevis said: Here’s a not so good shot of the original valve on my 71. I think there’s quite a bit missing. The lines are still amazingly intact tho.. From what I can see, it looks to be correct but obviously bent to stop it from hitting the control arm. The link rod is long gone too. 1 Quote
willie Posted July 22, 2024 Posted July 22, 2024 21 minutes ago, Ron Tevis said: Here’s a not so good shot of the original valve on my 71. I think there’s quite a bit missing. The lines are still amazingly intact tho.. Hey Ron, the bent arm is no problem as it can be taken off and straightened out. Looks like everything else is there, other than the arm.. But i am sure if you just took this pic, its time to change those fuel hoses and dont forget to save and reinstall that plastic plug in the hose!!! 1 Quote
MC-71 Posted July 22, 2024 Posted July 22, 2024 Have you ever tried Mc master & Carr. They supply a lot of hard to find parts. 1 Quote
Dtret Posted July 22, 2024 Author Posted July 22, 2024 7 hours ago, MC-71 said: Have you ever tried Mc master & Carr. They supply a lot of hard to find parts. Yes I did. And no they don’t. Today I made a rather out of the way pit stop to Dayton Air Supply ( the company that originally made the G67 compressor and valves, back then it was called Dayton Air Products)) and asked them about the fittings and any other old stock they have. No old stock but they are checking on the fittings. 3 Quote
Dtret Posted July 22, 2024 Author Posted July 22, 2024 9 hours ago, Dtret said: From what I can see, it looks to be correct but obviously bent to stop it from hitting the control arm. The link rod is long gone too. If you get ambitious, after we are done eating beef at The Park ( lol) , and you want it fixed up, take it off and send it to me. I also agree with Willie on the vent lines. One is cracked. 2 Quote
Grant MacPherson Posted July 22, 2024 Posted July 22, 2024 Just did a check in Canada, 2 fittings showed up in Manitoba but was told they were scrapped. Day late and a dollar short! 2 1 Quote
Dtret Posted July 24, 2024 Author Posted July 24, 2024 Still in development phase but not so bad for first try. It will work perfectly as is. 7 Quote
Leghome Posted July 25, 2024 Posted July 25, 2024 5 hours ago, Dtret said: Still in development phase but not so bad for first try. It will work perfectly as is. Well we can almost see your shoes so it must be you 1 2 Quote
Dtret Posted July 25, 2024 Author Posted July 25, 2024 Finished. I may try something different on the next batch but I know that they are a lot stronger then the originals. 8 Quote
Dtret Posted July 28, 2024 Author Posted July 28, 2024 48 minutes ago, overdrive said: Looks good. How much are the linkages? Dan These are just tests. If I do make some for sale I want to make sure the body is smooth. I did them all out of 1/4 28 ( because that’s the factory thread pitch) but the selection of parts wasn’t nearly as good as 1/4 20. I’ll keep the group informed on the progress. 6 Quote
