anyone have the torq specs for all the front end susp. i just replaced the whole thing and want to make sure when i set it on the ground i torq it all correctly. thanks
if anybody needs to torque specs for the whole front susp. i just found them in my haynes repair manual.
upper control arm pivot shaft-to-frame nuts
1970....50 lbs
1971-1975...55 lbs
upper control arm pivot shaft-to-bushing bolts
1970-1973....45 lbs
upper ball joints-to-control amrm bolts
all.....10lbs
upper balljoint stud-to-steering knuckle nut
1970-1973....50 lbs
lower balljoint stud-to-steering knuckle
1970-1973....80 lbs
lower control arm bushing-to-frame bolt and nut
1970-1971....80 lbs
1972-1973....85 lbs
outer tierod end-to-steering nuckle
1970-1979....35 lbs
inner tierod-to-intermediate rod nut
1970-1978....35 lbs
tie-rod adjuster sleeve clamp nut
1970....132 in-lbs
1971-1978....22 lbs
pitman arm-to-steering gear shaft nut
1970....140 lbs
1971 and later....185
pitman arm-to-intermediate rod nut
1970-1971....50 lbs
1972-later....45 lbs
idler arm-to-intermediate rod nut
1970-1973....50 lbs
idler arm-to-frame nuts
1970-1973....35 lbs
intermediate shaft pinch bolts
1970-1978....30 lbs
It is inch pound Allan smile so that would be 11 foot pounds...
  • 4 years later...
Bolting on the BMR stuff, searched for this - are these numbers all inch-pounds then?
No...ft. lbs. The tie-rod adjuster sleeve clamp nut for the 70 was listed as in. lbs.
