My 71 has 8" Corvette rally wheels with a 4'' backspacing according to the wheel code AZ, the car has 275/60/15 on it but they rub on the outside of the tires, if anyone has trimmed the rear wheel openings are you using a grinding wheel or a cutting wheel or rolling the inner lip.
Thanks in advance.
Thanks in advance.
There are many thoughts/experience on this. When I put my drag radials on they rubbed making turns at 30 mph. Some will say drag racing is a straight line, but I still have to turn off the track 🤣 I trimmed/cut mine back a tad. If you cut remember your exposing new bare metal, treat it to avoid rust .
  • Thank You! 1
If you're looking for a set of rally wheels to help you out, I have a pair of 8" rims  with the 5" offset you need. I'm running a pair  with 5" backspacing and 275/60 /15" Nitto drag radials (diamondback redlines) .That back spacing is the wrong way on these Monte Carlo's. I would not want you shave your fenders to run this set-up.post-259-0-06116300-1484180397_thumb.jpg
Is there a make or model that rim fits with the 5" BS
Right, let's not have to shave!!!
I just crawled under the car to look at the inside clearance, the previous owner put 3" exhaust all the way to the tailpipes so I have no room to go inward, so I will drop back to a 255/60/15
