1 hour ago, Jeff Dodson said:
Is there a real fix. I don't particularly like the angle of the MASTER / BOOSTER
It's not broken, that's how GM designed it.
You could remove the booster altogether, go manual brakes. Master cylinder bolts directly to firewall & actuator rod attaches on upper hole of brake pedal. Certainly a step backwards though.
Hydroboost is an option, overkill, and kinda ugly.
Or use this:
https://www.jegs.com/i/JEGS/555/631232/10002/-1?srsltid=AfmBOork-UbFns-Wxuw8hF4w_qnry31edi6x0-pDQuhISVOFmlY_VhhM074
  • Haha 1
The real beauty of it is in the attempt..... Not even a "higher power" gets it right every time. ;)
If it isn't broke........
There's always this option..
https://mpbrakes.com/product/1968-ford-bronco-power-brake-conversion-kit-8-dual-diaphragm-booster/?srsltid=AfmBOoo368kruaBIzBbtaKF07zLgkZ4jC3AAy2-TQ52Xvf4BY3xtkZRL
  • Haha 1
50 minutes ago, Scott S. said:
Could always go with the tried and true hand brake...... ??
Flintstone.....just need a Sawzall.
  • Haha 2
I was thinking the same thing!!!  lol
