That’s the same type of bracket they all came with. It does not attach to the head so that style should carry over.
22 hours ago, Scott S. said:
That is the bracket My 72 had but I had to modify it so my thermostat housing would work on my new heads I installed last year.  S now it only has a two mounting instead of the 3 point that it was. The mounting point on the intake got lopped off and shortened so it is only about 1" wide at the alternator
If you stare at something long enough, you'll eventually figure it out.  ;)
I ended up ordering a black billet style from CVF racing.  It should work great.
This company can covert everything to a serpentine belt system and include all the pumps and pulleys.  It is expensive but looks really interesting!  Maybe someday?
And some $$$$$....
16 hours ago, Scott S. said:
And some $$$$$....
Those kits look pretty affordable as for what you're getting. Some of these kits you see start in the $2000 range.
22 hours ago, bob 71 said:
if you can find brackets from mid 60s 283/307/327 engines
Good to know. :)
  • 3 weeks later...
The alternator bracket conversion from CVF Racing worked flawlessly.  I had all the other brackets and pulleys powder coated and they came back on Thursday.  I think I finally have all the engine and transmission parts I need to finish it up.  Hopefully next week I will have some completed pictures of the engine bay.  If the snow will melt soon, I'll be taking it out for a test run ASAP!
Pretty excited.  I've replaced or refurbished 100% of the mechanical and rubber parts on the car in the last eight months with the exception of the AC unit.  That will be a project for another day.  Now I'll be working on the rebuild of the old 350 engine/tranny to put in one of my '70's (which I call Blueberry).  I'll also be doing a new interior on Pickle this year which will only leave the paint and vinyl top to finish up in the future.
Here are a couple of pictures of that bracket.  You can also see I bought a Holley valve cover and air cleaner dress up kit.  I think they will look better than the stock ones.  A little irony here since I'm running a Rochester QuadraJet!
New power steering pump and lines.  I'm glad I did that because when I took the old lines out, the undersides were in rough shape.
Converting to HEI.  Decided to go with the stock exhaust.  I gave the engine bay a rattle can overhaul.  Taking my time and doing it right.
Oh, the stock tranny pan is a little bent which is causing it to leak even though it is a fresh rebuild.  This is probably from moving it 47 times on my garage floor over the years!  I ordered a new Mr. Gasket ribbed pan that will look similar to the valve covers - not that anyone looks down there but I'll know. 😉
  • Like 5
I'm trying to match the new body color.  I'm going to repaint the car the '71 MC lime green with a black vinyl top as opposed to the Cottonwood green with the green vinyl top.
  • 3 weeks later...
Well I have finally got the engine/transmission swap done and I've put on about 30 miles.  No leaks and everything seems to be running great.  I couldn't be happier!!!😀
Next steps will be dual exhaust and then move to interior and then exterior.  I may be waiting on the interior and exterior as I move on to one of my 1970 cars (Blueberry) in order to get it running and driving.  I'll keep everyone posted.
  • Like 8
Just a suggestion… Pull those exhaust manifolds off when you do your dual exhaust, strip, and coat factory color or black.  As it sits now, the rust completely kills what you’re trying to accomplish with the motor painted.
  • Like 6
I agree with Glen.  Positive criticism is not a negative comment but it is helpful.  :yay:
Humm.  I did not realize #1 - those were originally painted black and #2 - they could be repainted.  Sounds like a great idea.
What kind of paint do I need to use to paint an exhaust manifold?  Do you have to sandblast them?  Could I have them sandblasted and powder coated?
I'd suggest sandblasting and some sort of high heat ceramic type paint. Maybe Aaron will chime in he's done a couple sets I think. Not sure about powder coating.
The last couple cars I did for people with cast iron manifolds, I sand blasted them and used POR-15 high temp cast iron paint. It's only been one season, but both cars still look as good as the day they left the shop.
I cured them in the barbeque grill (after cleaning it really good of all grease, etc.), with accurate temperature monitoring to be sure it was all done correct. No issues so far...
  • Like 7
To the best of my knowledge, powder coating will not work. Also they were never black or coated with anything from the factory. Eastwood has a high temp exhaust manifold paint, VHT, and Por15 has some also. Definitely sandblast first. I would go with the cast iron color. Jet Hot coating is another alternative, but you have to send your manifolds to them.The cost would be considerably more. They coated the headers on my Camaro about 28 years ago, and they still look like the day they were done. Not sure what they charge these days.
Just did these for my 71. Eastwood exhaust manifold paint.
  • Like 6
  • Yay! 1
Same here.  I've used POR-15 a few times and have never seen it flake off.
And the shoes make it into another photo..... :k
  • Haha 3
