Tonka Man Posted October 23, 2024 Posted October 23, 2024 What is the trick to getting the cover off of the dome light of a '71? Quote
willie Posted October 23, 2024 Posted October 23, 2024 Nathan i think you just squeeze it where the tabs are!! Maybe someone else can confirm this but i think that's how the cover is removed. 1 Quote
714024SPEED Posted October 23, 2024 Posted October 23, 2024 Willie is correct,it has three tabs that hold it in squeeze it and it will come off. If it's original it may be brittle and crack. 2 Quote
Scott S. Posted October 23, 2024 Posted October 23, 2024 I found even some of the ones you buy "new" are brittle. The replacement I got for my '70 cracked when I installed it. Quote
Tonka Man Posted October 24, 2024 Author Posted October 24, 2024 There is a grey ring around the top that is close to the headliner and then the "clear" plastic part that is inside that. Do I squeeze the grey ring or the clear lens? Quote
Dtret Posted October 24, 2024 Posted October 24, 2024 Clear lense. The grey part is screwed to the roof. 3 Quote
