Hey guys! Hope all is well, and Happy New Year!!  So quick question is this port in the carb. Suppose to be capped off?
This is where it runs on my car. its the small hose in the pics.
Ahh, I see. I don’t have the catch can on my car, it didn’t come with one.
One is ported vacuum and the other one should be full vacuum. I'd cap off the one you're not using.
  • Thank You! 1
I run my vacuum advance off that port (full Vacuum), I run the catch can vacuum to the brake booster line. I just use on of those multiple style vacuum connectors that you cut to fit your size hoses. that port on the side you have your vacuum advance is progressive type vacuum it comes in at about 1500 rpm's.
Hey Dan…. Why the roller coaster inspired fuel hose run?
  • Confused 1
  • Kook 1
That’s the way I bought the car, still figuring out other peoples problems. Lol  any suggestions? I was thinking of putting a 650 double pumper on it with the metal fuel line
Ahh I see. I don’t have a catch can in the car, it didn’t come with one. I know there’s a hissing sound that comes from that port, so I was just wondering if I should just cap it off.
Cap it off for now. None of the ports should be open. Depending on its flow pattern and rate it could be set up for the old school type air cleaner.
  • Thank You! 1
Don't mind him some forums have an ignore button for characters like that 🤣
Honestly I did have to scroll back through the photos to understand the comment, and I did laugh.
Yea a dual feed line will clean up that area nicely. Focus on the importance stuff first, the aesthetics will follow suit in short order.
Some uf us have caused "the other people problems" in our past and paying the karma back now 🤣
  • Haha 1
