These, I'm thinking 1 goes to the temp sensor because there is shorter 1 that stops close to distributor for the Oil sensor. The other two, not sure. The others hanging in the back are AC WIRES
TCS wire ????
The dark green should be the temp sender wire, and I'm thinking that the other one goes to the TCS.
3 minutes ago, Scott S. said:
TCS wire ????
Ditto
They can, but it goes to the transmission,  idle solenoid, temperature switch,  etc. Best bet is to get a factory service manual,  it explains the system in a lot of detail, and has wiring diagrams.
It'll be good to have it on hand too, so we can point you to certain sections while on the phone. An assembly manual, and Fisher Body manual are a good idea too.
