Hey guys, recently bought a new e brake cable kit from opg and having trouble with the cable routing, Not sure where the s hooks anchor, every place I try them the cable isn't long  enough, Its a 70 with a 350th and a gforce cross member. any help would be appreciated.
Is the new cable a different length than the old? I don't have pics of mine sorry
Any chance you were given the cable for an mc with a th400?   It’s a shorter cable due to the crossmember sitting further back.
Ahh Hah, Now I know why my cable is too long (adjusted all the way up) !! I installed the turbo 400 (previous 350 & 2004r ), which means the crossmember moved more to the rear axle, making the attach point shorter. Who knew!! Never thought they would make the cable different lengths. Thank You Frank!  I'm in hot pursuit of a correct cable.
I checked the specs on the length and it said 90 9/16" which is what I have. double checked part number for 350Th
I think I will have to engineer something because of the custom crossmember. IDK for sure but the only images I can find are anchored on the cross member but it is way up there towards the front.
Sounds like the custom cross member may be the problem.  Any time you modify something from stock it usually requires a couple other things to be modified.
I think I got it figured out, if it was on the cross member originally it would have to have a long s hook, I found 3 points of anchor that will work, I just have to put something on the cable where it rubs on the floorboard, shrink tube maybe. thanks for the replys.
  • Like 5
I'm thinking Brian got it right about the aftermarket cross member causing problems....
I didn't have any issues with the cable when I moved the factory cross member back 6" for my 200R4, and Brian mentioned he'd had one in as well.
McMaster Carr has some 4 to 1 shrink tubing that I used on my emergency brake cables by the floor pans.
