Hopefully someone can help me out ? Is the front ot the quarter panel but welded to the rocker or are there spot welds somewhere I'm not seeing
Jason, i cant answer your question, but someone will soon!!!  However i would take all of those plastic clips off, especially the black one and save them.
I’m not 100 percent sure but I would believe it is spot welded. Look for seam sealer on the inside.
There are spot weld ,the quarter panel has a lip on it that is spot welded to the top of the rocker. If you wire wheel the top you should see them easier.good luck
  • Thank You! 1
This man has it right on the money. probably the hardest spot welds to get to, they are INSIDE the quarter, on the front lip that goes above the rocker.
  • Thank You! 2
