For those who have made the change to the Tremec 5 speed what ratio (close or wide)did you select? Also what Overdrive?
Depends what rear gears you have, and engine torque.
I put the wide ratio, with .72 5th gear in my Camaro. I already had existing 3.08 gears in the back from the Doug Nash 5 speed that was in there. With the 454 in the car, first gear is kinda useless though. If I had to do it again, I'd maybe look into one of the other boxes. Tough call...
The car came with 2.73. Silversport quoted a close ratio. Initially I'm trying to decide to move to 3.73 with the close ratio or stick with the 2.73 and a wide ratio. Opinions welcome. Motor is a 402 with a bit of a cam.
3 hours ago, 70white402 said:
My monte has a 496 with a close ratio 5 speed tremec and 373 rear. Hold on tight.
I would most certainly like a ride in this Monte! Sounds like a good time!!🙂
I would give the Tremec Technical Support a call and speak with the engineers regarding it. They can assist you in picking the proper transmission and gear ratio for your application.
  • 2 months later...
The M20 wide ratio has a lower 1st gear than the M21 or M22 which are the same.
