Monte_72 Posted April 8 Posted April 8 Anyone have a floor shift with tilt steering column you’d consider parting with? Quote
cny first gen 71 Posted April 8 Posted April 8 I have a column shift one but not floor shift. I still haven't put it in my car yet had it for a few years. 2 Quote
willie Posted April 8 Posted April 8 Ben if Dennis doesn't have it check in the resourses section on the top right and look for Leo or Steve Demmers they might have both pieces for you!!! 2 Quote
Dtret Posted April 9 Posted April 9 That’s the second most sought after column. 4 speed tilt is first. 2 Quote
Chevy Dave Posted April 9 Posted April 9 Be careful buying a used column that has not been rebuilt. Last summer I had to send my tilt, floor shift column to California to be rebuilt and it cost over $700 for parts, labor and shipping. The issue was the key would not engage the ignition switch because of a bad rack and gear. 2 Quote
willie Posted April 9 Posted April 9 1 hour ago, Dtret said: That’s the second most sought after column. 4 speed tilt is first. Ok Dennis i will bite, what is the difference??? And OOOCCHHH!!!!!! Quote
Monte_72 Posted April 9 Author Posted April 9 5 hours ago, willie said: Ben if Dennis doesn't have it check in the resourses section on the top right and look for Leo or Steve Demmers they might have both pieces for you!!! Thanks Willie! Quote
Monte_72 Posted April 9 Author Posted April 9 2 hours ago, Chevy Dave said: Be careful buying a used column that has not been rebuilt. Last summer I had to send my tilt, floor shift column to California to be rebuilt and it cost over $700 for parts, labor and shipping. The issue was the key would not engage the ignition switch because of a bad rack and gear. Thank you for this information! 2 Quote
Monte_72 Posted April 9 Author Posted April 9 3 hours ago, Dtret said: I seen one on marketplace in Texas for 899. Thanks Dennis! Quote
Dtret Posted April 9 Posted April 9 8 hours ago, willie said: Ok Dennis i will bite, what is the difference??? And OOOCCHHH!!!!!! The tab that is on the column for the lock-out rod is longer with a small double 90 degree bend, the 4 speed is just short and straight. 4 Quote
willie Posted April 9 Posted April 9 53 minutes ago, Dtret said: The tab that is on the column for the lock-out rod is longer with a small double 90 degree bend, the 4 speed is just short and straight. See you learn something new everyday here!!!!!! Tkx Dennis 4 Quote
420ponies Posted April 9 Posted April 9 I've had my tilt apart 3 times, tell me about it. But, someone on here(MCFan?), posted a very detailed repair sheet on it. Just followed along and it was fixed. Does anyone remember what happened at the gas station ,when I filled up and was ready to come to Syracuse for the National's and the park lock broke and I couldn't turn the key? It locked everything out. Hopefully it's fixed for another 46 yrs!! 2 Quote
Montemedic Posted April 9 Posted April 9 And I still kid you about not making the Syracuse Nationals that year. Definitely an original excuse !!! 2 Quote
stangeba Posted April 9 Posted April 9 Tilt was one of the best things I changed on my (still Column shift) 71 Monte. I thought someday I would add bucket seats, found a pair but never did the change. I think I have an extra Column shift TILT assembly in the basement. I did have a bad WOBBLE in my tilt steering wheel and did repair it a few years ago. 2 Quote
