Glen Posted April 23 Posted April 23 On 4/18/2025 at 7:52 PM, Joselk1 said: I like both caps so I switch them up. Looks great, Gary. I may have to pick up a set of the shorter caps to mix things up from time to time. I’m really liking the ride height… what are you using for springs and shocks? 2 Quote
Joselk1 Posted April 23 Posted April 23 8 hours ago, Glen said: Looks great, Gary. I may have to pick up a set of the shorter caps to mix things up from time to time. I’m really liking the ride height… what are you using for springs and shocks? Thanks… Rear springs are Moog 5379 and fronts are 6330. Both stock replacement springs for a big bloc. If I were doing it over I’d use the heavier El Camino rear springs for just a bit more height in the rear. My rear tires are 275/60/15 so they are 28”. tall and they don’t rub at all. I’m running Bilstein front shocks and adjustable Viking in the rear. 3 1 Quote
Joselk1 Posted April 23 Posted April 23 Just now, Joselk1 said: Thanks… Rear springs are Moog 5379 and fronts are 6330. Both stock replacement springs for a big bloc. If I were doing it over I’d use the heavier El Camino rear springs for just a bit more height in the rear. My rear tires are 275/60/15 so they are 28”. tall and they don’t rub at all. I’m running Bilstein front shocks and adjustable Viking in the rear. One more thing that helped my ride height is all new body mount bushing. 4 Quote
Scott S. Posted April 23 Posted April 23 8 hours ago, Joselk1 said: Thanks… Rear springs are Moog 5379 and fronts are 6330. Both stock replacement springs for a big bloc. If I were doing it over I’d use the heavier El Camino rear springs for just a bit more height in the rear. My rear tires are 275/60/15 so they are 28”. tall and they don’t rub at all. I’m running Bilstein front shocks and adjustable Viking in the rear. 8 hours ago, Joselk1 said: Thanks… Rear springs are Moog 5379 and fronts are 6330. Both stock replacement springs for a big bloc. If I were doing it over I’d use the heavier El Camino rear springs for just a bit more height in the rear. My rear tires are 275/60/15 so they are 28”. tall and they don’t rub at all. I’m running Bilstein front shocks and adjustable Viking in the rear. If you're looking for more height, I'd go with the El Camino springs..... Just installed a set of 5379's I got from 420ponies, and although they did add a lot of firmness, which was what I was looking for. But even with a 1" spacer added, I only gained about 3/4". I'm running a P255r60/15", 27" tall. 4 Quote
Joselk1 Posted April 24 Posted April 24 3 hours ago, Scott S. said: If you're looking for more height, I'd go with the El Camino springs..... Just installed a set of 5379's I got from 420ponies, and although they did add a lot of firmness, which was what I was looking for. But even with a 1" spacer added, I only gained about 3/4". I'm running a P255r60/15", 27" tall. My 28” tires fit because my 8” Rally wheels have 5” backspace. 2 Quote
rottenx8 Posted April 24 Posted April 24 On 4/18/2025 at 8:52 PM, Joselk1 said: I like both caps so I switch them up. Wow, never a fan of green, after many years in the Army. That is one sweet SS, even in green!!! I agree with both caps! Either one, you can't go wrong. Doug 1 1 Quote
Scott S. Posted April 24 Posted April 24 19 hours ago, Joselk1 said: My 28” tires fit because my 8” Rally wheels have 5” backspace. Corvette wheels... I've just got the factory Chevelle 8" ones. 1 Quote
Scott S. Posted April 24 Posted April 24 1 minute ago, rottenx8 said: Wow, never a fan of green, after many years in the Army. That is one sweet SS, even in green!!! I agree with both caps! Either one, you can't go wrong. Doug How about khaki or camo ??? 1 Quote
Robnhood Posted April 25 Posted April 25 These are the wheels that were originally on my monte when I got it. I liked them, but I really don't think they work on a monte. They were also rusted and pitted. I gave them to a friend of mine for his rat rod. I upgraded to these and finallly settled on these I have better rings on the car now, but I don't have a picture. I am a big fan of how it looks with the derby caps. Although the 3 spoke caps look cool too. 3 Quote
Robnhood Posted April 25 Posted April 25 Just now, Robnhood said: These are the wheels that were originally on my monte when I got it. I liked them, but I really don't think they work on a monte. They were also rusted and pitted. I gave them to a friend of mine for his rat rod. BTW: The hood pins are long since gone. In my honest opinion, they just plan don't belong on my monte carlo. I tend to think in the terms of gentlemen's muscle car. Not knocking if you have them, just isn't for me. 3 Quote
Rob Peters Posted April 25 Posted April 25 45 minutes ago, Robnhood said: These are the wheels that were originally on my monte when I got it. I liked them, but I really don't think they work on a monte. They were also rusted and pitted. I gave them to a friend of mine for his rat rod. I upgraded to these and finallly settled on these I have better rings on the car now, but I don't have a picture. I am a big fan of how it looks with the derby caps. Although the 3 spoke caps look cool too. You have chosen wisely!!! Your Monte looks great. You should join us at our Mini-Meet in Carlisle at the GM Nationals June 19th to June 22nd. Let me know if you would be interested and I will help get your set up and get your Monte registered with Carlisle Events. As of right now I have 42 members registered with me to attend. It is a great way to meet a large number of our members and a large number of Monte's all in the same place. (BTW, members even show up without their Monte if their Monte's are not able to attend.) rob 3 Quote
rottenx8 Posted April 26 Posted April 26 On 4/24/2025 at 5:44 PM, Scott S. said: How about khaki or camo ??? HHMMMM, interesting thought. I don't think camo would look good on a Monte,unless you were going for the hillbilly look. 1 Quote
RON T Posted April 26 Posted April 26 I had the choice of either when I bought my 71 , but I chose the derby. I rotate between the rally wheels with derby caps and the Black chrome American racer 5 spoke.. 3 Quote
RON T Posted April 26 Posted April 26 19 minutes ago, rottenx8 said: HHMMMM, interesting thought. I don't think camo would look good on a Monte,unless you were going for the hillbilly look. Hey! . Watch it, I see a lot of those down here in Kentuk.! 😂 1 3 Quote
Dtret Posted April 26 Posted April 26 When I bought the 72 Custom it came with 15x6 Cragers for the front and 15x7 Cragers for the rear. Every spring the PO would dismount the rear tires and put them on the Cragers and the front had tires , being the small size ready to go. In the fall he’d change back to the Po2’s. It was a 4 season car. It I can find a nice set of tires cheap ( lol). I may do the switch once in a while. Not a big fan of any hubcaps, they make the cars look old ( no offense, my opinion). 2 Quote
Rob Peters Posted April 26 Posted April 26 1 hour ago, Ron Tevis said: I had the choice of either when I bought my 71 , but I chose the derby. I rotate between the rally wheels with derby caps and the Black chrome American racer 5 spoke.. Personally, I like your car dressed in the Rally wheels and white stripe tires. Whatever the stickers are on the windshield and 1/4 glass I am sure add extra horsepower. 👍 rob 1 Quote
RON T Posted April 26 Posted April 26 I wonder if they make this for a first generation Monte?. Cool :)😎 😅 1 1 1 Quote
cny first gen 71 Posted April 26 Posted April 26 2 minutes ago, Ron Tevis said: I wonder if they make this for a first generation Monte?. Cool 😎 😅 Oh no I hope not 🤣 Quote
RON T Posted April 26 Posted April 26 24 minutes ago, Rob Peters said: Personally, I like your car dressed in the Rally wheels and white stripe tires. Whatever the stickers are on the windshield and 1/4 glass I am sure add extra horsepower. 👍 rob I agree, however, at the car shows in this area it’s all about the muscle car look instead of the family car look.. I’ve tried both in this area and always come in first or second only by changing the wheels 🛞 to chrome.. I’m not sure about other areas of the country however.. 3 Quote
Wd71MC Posted April 26 Posted April 26 When I purchased my Monte these are the wheels it came with the American Racing 5 spoke. 2 Quote
Scott S. Posted April 26 Posted April 26 29 minutes ago, Leghome said: more than likely that caero is a wrap not paint And it is available for pretty much any car.... Quote
Scott S. Posted April 26 Posted April 26 5 hours ago, Dtret said: When I bought the 72 Custom it came with 15x6 Cragers for the front and 15x7 Cragers for the rear. Every spring the PO would dismount the rear tires and put them on the Cragers and the front had tires , being the small size ready to go. In the fall he’d change back to the Po2’s. It was a 4 season car. It I can find a nice set of tires cheap ( lol). I may do the switch once in a while. Not a big fan of any hubcaps, they make the cars look old ( no offense, my opinion). I used to like the Crager wheels until I watched a buddy spin the centers out while doing a burnout..... NOT a pretty sight. 1 Quote
