I switched from the stock split bench front seat to a set of buckets, and I just realized that I would need the bucket style Black inner seat belts.
Here is a picture of my MORRIS 3 point replacement, showing the difference of the bench vs bucket seat female end of the belts.
I don't know if OEM is like this or not. I suggest you replace yours with the MORRIS 3 point safety belt system.
Unfortunately, I cannot spend $300+ for a set of seat belts.
I'd rather just replace the inner two seat belt units close to the trans tunnel.
I do not have them. Sorry.
  • 3 weeks later...
Also, I need (1) chrome horseshoe for the rear taillights.
I didn't realize that one has some pitting in it. I'd rather have an OEM for them as I read that the aftermarket ones can be a little bit off spec.
I have a bunch but none that are not pitted
  • Sad 1
Still mainly looking for a set of black factory inner bucket seat belts if someone on here has some.
  • 72 Monte Carlo changed the title to Front bucket black inner seat belts and black rear quarter side panels
  • 1 month later...
Sorry, I have a bench seat.
In 71 there was an option for deluxe seat belts. The female connector was small compared to the stock / standard belt connector. (See Picture)IMG_2915small.thumb.JPG.1c96dff3632e02f4332f313f6b142634.JPG
The standard stock system required you had to tighten your seatbelt, it was NOT self adjusting like the deluxe. The deluxe SHOULDER belts also required you tighten them.
I don't know what 72 had.
Good luck
  • 4 weeks later...
My seat belts have the automatic retractable male side and the 2-1/2" wide female side of the belts.
My original question was does the inner front belts between the bucket seats and the center console, have the stiff outer coating so that they sit in place so a person doesn't have to hunt for them?
Where the inners bolt to the floor they have a vinyl, maybe something a little harder, cover that goes over them with a little snap button.
They're typical for most "A/G" body cars.....
Someone on one of the Chevelle sites might have a set, or if you've got a local wrecker that has cars that old, you might have some luck there.
22 hours ago, GRAY 70 Monte Carlo said:
Mine do not they sit in the pockets mounted to the consoleIMG_3687.thumb.jpeg.a2fb49ac3fb2d47bfb941c933c8a667f.jpeg
That's a lot of buckles..... But then again, '70's didn't have shoulder belts. ;)
70’s do have shoulder restraints. One buckle for the lap restraints one buckle for the shoulder restraints
No shoulder belts in Montelishi.... But she was assembled in January.
That might be the difference.
Is this style considered the standard or deluxe seat belt?
I'm assuming that only the deluxe style would have the vinyl covered inner female receptacle side of the seat belts.
Check out the MORRIS 3 point safety belt system for the ft two seats.
I like mine.
