GRAY 70 Monte Carlo Posted May 13 Posted May 13 Does anyone going to Eastern Meet in Sommerset have either a ash tray assembly or correct springs for a 70 model for sale also need 2 chrome armrest bases Quote
Dtret Posted May 13 Posted May 13 Any of the chrome bases I have are not really chrome anymore. You may want to check The Parts Place Quote
GRAY 70 Monte Carlo Posted May 13 Author Posted May 13 Could also use black armrest bases just don’t want to order a/m parts unless no other choices Quote
Dtret Posted May 13 Posted May 13 Maybe I’m not thinking of the part you’re thinking of. I’m thinking the chrome “ sheet “ that the armrest base screws to. The base itself will be interior color and then of course the pad. The ones I got from The Parts Place were pretty much perfect. 3 Quote
GRAY 70 Monte Carlo Posted May 13 Author Posted May 13 That’s what I needed thank you ordering now 1 Quote
Dtret Posted May 13 Posted May 13 8 hours ago, GRAY 70 Monte Carlo said: That’s what I needed thank you ordering now They probably have the ashtray springs too. 2 Quote
RON T Posted May 15 Posted May 15 A word of caution, if you use the armrest back plates, AND , you have to replace the door latch shaft, the replacement door latch shaft is to short. I have not found the longer door latch shaft mechanism anywhere… 3 Quote
GRAY 70 Monte Carlo Posted May 16 Author Posted May 16 I don’t understand why rod would need to be longer if only replacing the inner trim .all I need is the base next to trim panel mine is black but all I have found is chrome see attached picture .i would prefer black if I could get them 1 Quote
GRAY 70 Monte Carlo Posted May 16 Author Posted May 16 If you look closely at upper edge is broken off 1 Quote
Dtret Posted May 16 Posted May 16 If you flip it over or scratch it , is it chrome underneath the black? 1 Quote
cbolt Posted May 16 Posted May 16 I replaced mine, and if I still have the originals I will dig them up and bring them to Somerset. Ill post up if I find them and pack them. I may have pitched them but you never know. 2 Quote
willie Posted May 16 Posted May 16 Greg i would think some PO just painted it black, just ask for a used OEM one and paint it black. 2 Quote
GRAY 70 Monte Carlo Posted May 17 Author Posted May 17 Sorry it’s taken some time for me to reply I have been on the the road all day.To answer the question they were not painted just black I couldn’t find any that were not chrome and figured since trim panel already has chrome accents it would work but would be glad to find used and paint them if anyone has a set to sell If not will just order a/m chrome that Dtret posted Quote
Dtret Posted May 17 Posted May 17 I’m sure I have a set somewhere. Let me get out there after the storms pass and I’ll let you know. 1 Quote
Dtret Posted May 21 Posted May 21 I did find some but the mount tabs are broken on all of them. Quote
