jbird72 Posted May 28 Posted May 28 So I understand that like half of us are still carburetors, but question, if anybody's running air gap manifold with a holly carb. Is there a fitting that anybody knows that will fit on that vacuum fitting underneath the carb? So I can run full manifold to the distributor I ordered one from summit.And it's a little over an eighth inch, too tall, I guess if I have to run a carb spacer, I could, but I really didn't want to I don't know if it would hurt or not any advice would be appreciated. 1 Quote
jbird72 Posted May 28 Author Posted May 28 Ill send. I ordered a 1 inch spacer. Just dont know bout hood clearence..dont wanna use drop down air cleaner. So that vacumn acess is right under accel pump arm. I dont think i have a choice 1 Quote
jft69z Posted May 28 Posted May 28 If there's a vacuum cap on that carb fitting now, a hose should just slip in place of it, unless I'm not seeing it? If its the larger fitting, like for a PCV hose, just use a reducer fitting. You could probably make something work with the fittings below: https://www.amazon.com/Dorman-47308-Vacuum-Tubing-Connector/dp/B002H9DD7Y more Dorman adapter fittings 1 Quote
jbird72 Posted May 28 Author Posted May 28 37 minutes ago, jft69z said: If there's a vacuum cap on that carb fitting now, a hose should just slip in place of it, unless I'm not seeing it? If its the larger fitting, like for a PCV hose, just use a reducer fitting. You could probably make something work with the fittings below: https://www.amazon.com/Dorman-47308-Vacuum-Tubing-Connector/dp/B002H9DD7Y more Dorman adapter fittings I ordered one similar. Still too tall. I dont wanna run vacumn for distributor off of carb i wanna run off manifold theres 50/50 on this but i wanna try and see difference 1 Quote
jbird72 Posted May 28 Author Posted May 28 40 minutes ago, jft69z said: If there's a vacuum cap on that carb fitting now, a hose should just slip in place of it, unless I'm not seeing it? If its the larger fitting, like for a PCV hose, just use a reducer fitting. You could probably make something work with the fittings below: https://www.amazon.com/Dorman-47308-Vacuum-Tubing-Connector/dp/B002H9DD7Y more Dorman adapter fittings This is what i ordered it claims low profile 2 Quote
jbird72 Posted May 28 Author Posted May 28 43 minutes ago, Dtret said: Is the fitting under the acc pump a hex plug? No its a allen type plug. I guess can get away maybe 1/2 in spacer but i ordered a 1 inch. Ive heard good and bad things bout spacers guess depends on everything on thr build Quote
jbird72 Posted May 28 Author Posted May 28 1 minute ago, jbird72 said: No its a allen type plug. I guess can get away maybe 1/2 in spacer but i ordered a 1 inch. Ive heard good and bad things bout spacers guess depends on everything on thr build I think edelbrock did on purpose so have to buy edelbrock carb 44 minutes ago, Dtret said: Is the fitting under the acc pump a hex plug? No its a allen type plug. I guess can get away maybe 1/2 in spacer but i ordered a 1 inch. Ive heard good and bad things bout spacers guess depends on everything on thr build Quote
Scott S. Posted May 28 Posted May 28 The taller the spacer, the straighter the air flow, which helps at higher RPM's..... The whole theory behind a tunnel ram. but I don't think there's a lot of difference between 1/2" and 1"... 1 Quote
jbird72 Posted May 28 Author Posted May 28 2 minutes ago, Scott S. said: The taller the spacer, the straighter the air flow, which helps at higher RPM's..... The whole theory behind a tunnel ram. but I don't think there's a lot of difference between 1/2" and 1"... Cool. Hope the hood closes 1 Quote
Scott S. Posted May 28 Posted May 28 The one thing I wonder about is using an outlet that close to one cylinder...... Something closer to a central location would give a minutely better balanced vacuum flow. Probably doesn't make that much of a difference, but it would be interesting to know. 1 Quote
Scott S. Posted May 28 Posted May 28 3 minutes ago, jbird72 said: Cool. Hope the hood closes Assuming you're using an aftermarket air cleaner, the height of the element could give you the space you're looking for. 1 Quote
Scott S. Posted May 28 Posted May 28 Just now, Scott S. said: Assuming you're using an aftermarket air cleaner, the height of the element could give you the space you're looking for. I had to use a spaced bottom pan to clear the acc. pump on my Edelbrock, so I just used a shorter filter to get clearance. 1 Quote
jbird72 Posted May 28 Author Posted May 28 11 minutes ago, Scott S. said: I had to use a spaced bottom pan to clear the acc. pump on my Edelbrock, so I just used a shorter filter to get clearance. Yu got a 4inch too...showoff lol i do have a dropdown bottom and a reg base i just dont like to use the dropdown ..more air restricion...horsepower is horsepower lol 1 Quote
jbird72 Posted May 28 Author Posted May 28 3 minutes ago, jbird72 said: Yu got a 4inch too...showoff lol i do have a dropdown bottom and a reg base i just dont like to use the dropdown ..more air restricion...horsepower is horsepower lol Nevermind looked taller Quote
Scott S. Posted May 28 Posted May 28 Nope... It's only a 3"..... Just looks bigger with the right background. Wish I had a better pic of the base plate... It adds about an inch of height to the whole thing. Makes it easier to get at the adjustments on the carb. 1 Quote
jbird72 Posted May 28 Author Posted May 28 1 minute ago, Scott S. said: Nope... It's only a 3"..... Just looks bigger with the right background. Wish I had a better pic of the base plate... It adds about an inch of height to the whole thing. Makes it easier to get at the adjustments on the carb. I like it. 1 Quote
Scott S. Posted May 28 Posted May 28 2 minutes ago, jbird72 said: I like it. It's still about a half inch too tall, but it's lower than what was in there when I bought Montelishi. The old felt liner had a definite circle indentation in it. 1 Quote
jbird72 Posted May 28 Author Posted May 28 1 minute ago, Scott S. said: It's still about a half inch too tall, but it's lower than what was in there when I bought Montelishi. The old felt liner had a definite circle indentation in it. Im missing mine. I was thinkin bout gettin one body shop 20 yrs ago didnt put back they also screwed the rocker trim instead of clips really pissed me off when i realized what was done i was 5 states away. Live and learn. Cheep paint means cheep labor ect... 1 Quote
Scott S. Posted May 28 Posted May 28 Just now, jbird72 said: Im missing mine. I was thinkin bout gettin one body shop 20 yrs ago didnt put back they also screwed the rocker trim instead of clips really pissed me off when i realized what was done i was 5 states away. Live and learn. Cheep paint means cheep labor ect... I hear your there !!!! I got my new one from Parts Place..... Cost more in shipping than the liner itself. I found that I had to ream the holes to get the clips to work without breaking them. 1 Quote
jbird72 Posted May 28 Author Posted May 28 1 minute ago, Scott S. said: I hear your there !!!! I got my new one from Parts Place..... Cost more in shipping than the liner itself. I found that I had to ream the holes to get the clips to work without breaking them. Ugg i need a headliner. Not lookin fwd to installing that for now ductape will do 1 Quote
jbird72 Posted May 28 Author Posted May 28 5 minutes ago, Scott S. said: I hear your there !!!! I got my new one from Parts Place..... Cost more in shipping than the liner itself. I found that I had to ream the holes to get the clips to work without breaking them. I see opgi has it for 36 bucks. 67 shipping. Ugg 1 Quote
Scott S. Posted May 28 Posted May 28 2 minutes ago, jbird72 said: I see opgi has it for 36 bucks. 67 shipping. Ugg Insane !!!! Almost cheaper for you to go pick it up. 1 Quote
jbird72 Posted May 28 Author Posted May 28 1 minute ago, Scott S. said: Insane !!!! Almost cheaper for you to go pick it up. Right Quote
